Ana içeriğe geç
Removing Minolta X-370 Lens Holder
Neye ihtiyacın var
  1. Removing Minolta X-370 Lens Holder, Battery: adım 1, 2 resimden 1. Removing Minolta X-370 Lens Holder, Battery: adım 1, 2 resimden 2.
    • Flip the camera so that the bottom is facing you.
    • Take a spare coin and unscrew the battery cover off.
  2. Removing Minolta X-370 Lens Holder: adım 2, 1 resimden 1.
    • Remove the batteries, making sure to note their proper alignment.
  3. Removing Minolta X-370 Lens Holder, Bottom Cover: adım 3, 2 resimden 1. Removing Minolta X-370 Lens Holder, Bottom Cover: adım 3, 2 resimden 2.
    • Remove two 4.8mm screws.
    • Remove one 3.4mm screw.
    • Remove one 2.65mm screw.
    • Lift off the back cover.
  4. Removing Minolta X-370 Lens Holder: adım 4, 1 resimden 1.
    • Remove three 3.5mm screws.
    • Remove two 3.8mm screws.
    • Remove one 6.35mm screw.
    • Remove one 4mm screw. Lift off the disk.
    • Remove one 5.11mm screw.
  5. Removing Minolta X-370 Lens Holder: adım 5, 1 resimden 1.
    • Lift up the silver, metal piece
    • Please note that some internal pieces may come loose during this process.
  6. Removing Minolta X-370 Lens Holder, Lens Holder: adım 6, 3 resimden 1. Removing Minolta X-370 Lens Holder, Lens Holder: adım 6, 3 resimden 2. Removing Minolta X-370 Lens Holder, Lens Holder: adım 6, 3 resimden 3.
    • Remove four 4.45mm screws and remove the alignment ring.
    • Remove the interior metal ring and the black plastic ring. Pay attention to the spring's location.
    • Pay attention to the alignment of the interior metal ring and the black plastic ring.
  7. Removing Minolta X-370 Lens Holder: adım 7, 3 resimden 1. Removing Minolta X-370 Lens Holder: adım 7, 3 resimden 2. Removing Minolta X-370 Lens Holder: adım 7, 3 resimden 3.
    • Remove the two black stoppers.
    • Using the metal spudger, remove the two triangular hangers.
  8. Removing Minolta X-370 Lens Holder: adım 8, 2 resimden 1. Removing Minolta X-370 Lens Holder: adım 8, 2 resimden 2.
    • Using the metal spudger, peel off the right leather cover.
    • Be careful not to tear the cover because you will need to use it again.
  9. Removing Minolta X-370 Lens Holder: adım 9, 3 resimden 1. Removing Minolta X-370 Lens Holder: adım 9, 3 resimden 2. Removing Minolta X-370 Lens Holder: adım 9, 3 resimden 3.
    • Use the metal spudger to remove both the grip cover and the left leather cover.
    • Be careful not to tear the covers because you will need to use them again.
  10. Removing Minolta X-370 Lens Holder: adım 10, 2 resimden 1. Removing Minolta X-370 Lens Holder: adım 10, 2 resimden 2.
    • Remove two 5.3mm screws.
    • Remove one 2.35mm screws.
  11. Removing Minolta X-370 Lens Holder: adım 11, 2 resimden 1. Removing Minolta X-370 Lens Holder: adım 11, 2 resimden 2.
    • Remove the left and right plastic covers.
  12. Removing Minolta X-370 Lens Holder: adım 12, 3 resimden 1. Removing Minolta X-370 Lens Holder: adım 12, 3 resimden 2. Removing Minolta X-370 Lens Holder: adım 12, 3 resimden 3.
    • Remove two 6.65mm screws.
    • Remove two 2.93mm screws.
    • Remove four 5.3mm screws.
    • Remove the black plastic lens holder.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Nick
525 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-7, Regan Spring 2011 Cal Poly, Team 8-7, Regan Spring 2011 üyesi
CPSU-REGAN-S11S8G7
4 Üyeler
9 adet Kılavuz yazıldı
Bir Yorum
I have Problems to assemble the new black plastic lens holder.
The space between camera Cup and the housing is very low.
Did someone have the same Problems ?
Klaus Kohlhas - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 26
Her zaman: 7,405
