Ana içeriğe geç
Giriş
Step-by-step guide to removing your phone's back plate.
Parçalar
Hiçbir parça belirtilmedi.
  1. Flip phone to see back cover. Using either finger or spugder tool press button located  near the top of phone by the antenna.
    • Flip phone to see back cover.
    • Using either finger or spugder tool press button located near the top of phone by the antenna.
  2. Pry up back plate from phone to reveal battery. Push button near bottom of battery using either your finger of the spudger.  This will release the battery.
    • Pry up back plate from phone to reveal battery.
    • Push button near bottom of battery using either your finger of the spudger. This will release the battery.
  3. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  4. Using a T6 Torx Screwdriver remove the four torxs on the back of the phone.
    • Using a T6 Torx Screwdriver remove the four torxs on the back of the phone.
  5. Simultaneously press indicated buttons on both sides of phone. Simultaneously press indicated buttons on both sides of phone.
    • Simultaneously press indicated buttons on both sides of phone.
  6. Separate back plate from the rest of phone.
    • Separate back plate from the rest of phone.
    • Make sure to not pull, there is a wire (circled on image) connecting the two plates.
Sonuç
Elizabeth OBrien
31 İtibar
7 adet Kılavuz yazıldı
Takım
Cal Poly, Team 30-40, Garner Spring 2010 Cal Poly, Team 30-40, Garner Spring 2010 üyesi
CPSU-GARNER-S10S30G40
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 4
Her zaman: 3,196
