Ana içeriğe geç
Giriş
This installation guide will help you remove the rear and front casing of your Nikon Coolpix 4600.
Parçalar
Hiçbir parça belirtilmedi.
  1. Locate the six screws on the outside of the camera (2 3.3 mm on the bottom, 2 5.25 mm on the left, and 2 5.25 mm on the right). Using a Phillips 00 screwdriver, remove all of the six screws.
    • Locate the six screws on the outside of the camera (2 3.3 mm on the bottom, 2 5.25 mm on the left, and 2 5.25 mm on the right).
    • Using a Phillips 00 screwdriver, remove all of the six screws.
  2. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  3. Carefully pull the front and back case apart. The front case is attached to internal components and cannot be removed independently.
    • Carefully pull the front and back case apart.
    • The front case is attached to internal components and cannot be removed independently.
  4. Look closely at the connection between the ribbon cable and the motherboard.  Locate the two grey tabs on either side of the connecting bracket.
    • Look closely at the connection between the ribbon cable and the motherboard. Locate the two grey tabs on either side of the connecting bracket.
    • Slide the grey tabs toward the bottom of camera. Gently disconnect the ribbon cable from the motherboard.
    • After disconnecting the data ribbon, you can now separate the back case from the front case.
Sonuç
Nathan Sperling
89 İtibar
4 adet Kılavuz yazıldı
Takım
Cal Poly, Team 9-43, Regan Spring 2012 Cal Poly, Team 9-43, Regan Spring 2012 üyesi
CPSU-REGAN-S12S9G43
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 2
Son 30 Gün: 4
Her zaman: 1,232
