Ana içeriğe geç
Removing Nikon Coolpix 4600 Front and Rear case
Neye ihtiyacın var
  1. Removing Nikon Coolpix 4600 Front and Rear case, Front and Rear Case: adım 1, 2 resimden 1. Removing Nikon Coolpix 4600 Front and Rear case, Front and Rear Case: adım 1, 2 resimden 2.
    • Find the six screws on the exterior of the camera: two 3.3 mm screws on the bottom and two 5.25 mm screws on both the left and right sides.
    • Using a Phillips 00 screwdriver, remove all of the six screws.
  2. Removing Nikon Coolpix 4600 Front and Rear case: adım 2, 2 resimden 1. Removing Nikon Coolpix 4600 Front and Rear case: adım 2, 2 resimden 2.
    • Gently separate the front and back casing by pulling them apart with your hands, being careful not to damage any internal components.
    • The front case is attached to internal components and cannot be removed independently.
  3. Removing Nikon Coolpix 4600 Front and Rear case: adım 3, 1 resimden 1.
    • Examine the connection between the ribbon cable and the motherboard closely. Identify the two grey tabs on each side of the connecting bracket.
    • Slide the grey tabs toward the bottom of the camera to release the ribbon cable. Gently disconnect the ribbon cable from the motherboard.
    • Once the ribbon cable is disconnected, you can now carefully separate the back case from the front case.
Sonuç
Nathan Sperling
119 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-43, Regan Spring 2012 Cal Poly, Team 9-43, Regan Spring 2012 üyesi
CPSU-REGAN-S12S9G43
5 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 1,585
