Giriş
Use this guide to cut off numerical keypad from your keyboard.
Why do this?
If you spend a lot of time typing and are experiencing pain in your right shoulder, numerical keypad may be the cause of your pain. When working with your mouse, your right hand is awkwardly positioned far right because of the useless numerical keypad.
There are myriad short keyboards on the market, but almost none retain the regular layout for insert/home/delete/arrows. This hurts me as much as my shoulder.
Neye ihtiyacın var
You can do this with most keyboards. I had an older Dell keyboard model L100.
4 farklı kişi bu kılavuzu tamamladı.
9 Yorum
this is awful !!
Manual hacksaw is probably the best choice. Any power tool is liable to burn the plastic and produce fumes which you don't want to be inhaling.
Can i do this to an aluminum extended keyboard usb apple?
Judging by the position of the cable, the pcb is placed away from the numerical keypad, so I would guess you should be able to do it.
Very good. this is what i was looking for… Thank you.
Very useful, exactly what I was looking for!
What can the other things you can do without a saw to cut it off?
