Ana içeriğe geç
Removing Olympus FE-210 Front Casing
Neye ihtiyacın var
  1. Removing Olympus FE-210 Front Casing, Battery: adım 1, 2 resimden 1. Removing Olympus FE-210 Front Casing, Battery: adım 1, 2 resimden 2.
    • The battery compartment is located on the bottom side of the camera. Push the button in, and slide the cover to get access to the batteries.
  2. Removing Olympus FE-210 Front Casing: adım 2, 2 resimden 1. Removing Olympus FE-210 Front Casing: adım 2, 2 resimden 2.
    • The batteries will slide right out.
    • When putting new batteries in, make sure they are pointing the right direction.
  3. Removing Olympus FE-210 Front Casing, Front Casing: adım 3, 3 resimden 1. Removing Olympus FE-210 Front Casing, Front Casing: adım 3, 3 resimden 2. Removing Olympus FE-210 Front Casing, Front Casing: adım 3, 3 resimden 3.
    • Remove the 7 screws holding the front case in place, with a #00 screwdriver.
    • Six screws are 3.6 mm.
    • The seventh screw is 3.2 mm.
  4. Removing Olympus FE-210 Front Casing: adım 4, 3 resimden 1. Removing Olympus FE-210 Front Casing: adım 4, 3 resimden 2. Removing Olympus FE-210 Front Casing: adım 4, 3 resimden 3.
    • Pulling the front case off, requires applying enough strength in the right areas.
    • The front case snaps into place in three places:
    • At the top and bottom of the battery side (opposite of side pictured) of the case.
    • Right in the middle of the DC-in side (side pictured) of the case.
    • Top of the camera, to the left of the power button.
    • Once those places are disconnected, the front case will pop right off.
    • The camera in the first two pictures is upside down. This is the best position to place your thumbs to remove the case.
Sonuç
Matt
796 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-36, Regan Winter 2011 Cal Poly, Team 4-36, Regan Winter 2011 üyesi
CPSU-REGAN-W11S4G36
3 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 1,598
