Giriş
Removing the rear camera casing will give you access to the inside of the camera.
Neye ihtiyacın var
The battery compartment is located on the bottom side of the camera. Push the button in, and slide the cover to get access to the batteries.
Remove the seven screws holding the front case in place, with a Phillips #00 screwdriver.
Six screws are 3.6 mm.
The seventh screw is 3.2 mm.
Insert an opening tool or spudger into the seam between the front case and body of the camera to release the clips holding it together.
These three places are located:
At the top and bottom of the battery side (opposite of side pictured) of the case.
Right in the middle of the DC-in side (side pictured) of the case.
Top of the camera, to the left of the power button.
Once those places are disconnected, the front case will pop right off.
Remove the 3.2 mm screw in the battery compartment using a #00 screwdriver.
Bir başkası bu kılavuzu tamamladı.
