Neye ihtiyacın var
Eject the disk tray from the DVD player before removing power supply.
Remove the three screws running along the back edge of case cover.
Remove the two screws from each side of the case cover.
Lift up the five tabs securing the front panel to the chassis. There are three on the bottom, and two on the inside edges of the panel. Panel should then lift off the player.
Remove the blue ribbon wire from its connector. When doing this, be cautious to not damage the connector.
Place forefinger under cable loop as shown, gripping with thumb.
Pull straight up. It should disconnect with little force.
Bir başkası bu kılavuzu tamamladı.
