Ana içeriğe geç
Removing Philips DC320 37 Bottom Panel
Neye ihtiyacın var
  1. Removing Philips DC320 37 Bottom Panel, Docking entertainment system: adım 1, 1 resimden 1.
    • Pry off the four white feet with the pointed end of the spudger
  2. Removing Philips DC320 37 Bottom Panel: adım 2, 1 resimden 1.
    • Gently unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
  3. Removing Philips DC320 37 Bottom Panel: adım 3, 1 resimden 1.
    • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • The connectors on the panel are fragile and may break.
  4. Removing Philips DC320 37 Bottom Panel: adım 4, 3 resimden 1. Removing Philips DC320 37 Bottom Panel: adım 4, 3 resimden 2. Removing Philips DC320 37 Bottom Panel: adım 4, 3 resimden 3.
    • Carefully pull up and out the four electrical connectors and two ribbon connectors that connect the bottom panel to the dock.
    • Electrical Connectors
    • Ribbon Connectors
    • The cables do not have a lot of slack in them. Be careful not to break the connectors.
    • One wire is soldered onto the bottom panel. Be careful not to break this bond.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Greg Lane
39 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-48, Amido Spring 2013 Cal Poly, Team 3-48, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S3G48
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 394
