Ana içeriğe geç
Removing Playstation 2 Slimline SCPH-7500x Outer Shell
Neye ihtiyacın var
    • Turn off the PlayStation 2 and carefully unplug it from the power source. Also, it is important to eject the CD from the console before flipping the it upside down.
  1. Removing Playstation 2 Slimline SCPH-7500x Outer Shell: adım 2, 1 resimden 1.
    • Locate the six feet on the bottom of the PS2.
    • Five of these feet are in plain sight while the last foot is located under the black void sticker on the back of the device.
    • Some versions of the console, such as the PAL Version, may not have this sticker. In this case, the foot or the screw should be in plain sight.
  2. Removing Playstation 2 Slimline SCPH-7500x Outer Shell: adım 3, 3 resimden 1. Removing Playstation 2 Slimline SCPH-7500x Outer Shell: adım 3, 3 resimden 2. Removing Playstation 2 Slimline SCPH-7500x Outer Shell: adım 3, 3 resimden 3.
    • Remove the five visible feet from the bottom of the device using a spudger.
  3. Removing Playstation 2 Slimline SCPH-7500x Outer Shell: adım 4, 2 resimden 1. Removing Playstation 2 Slimline SCPH-7500x Outer Shell: adım 4, 2 resimden 2.
    • Remove the sticker and then remove the 6th foot.
  4. Removing Playstation 2 Slimline SCPH-7500x Outer Shell: adım 5, 3 resimden 1. Removing Playstation 2 Slimline SCPH-7500x Outer Shell: adım 5, 3 resimden 2. Removing Playstation 2 Slimline SCPH-7500x Outer Shell: adım 5, 3 resimden 3.
    • After all of the feet have been removed, Use a Phillips #1 screwdriver to remove the six 4.0mm screws from the base of the PS2.
  5. Removing Playstation 2 Slimline SCPH-7500x Outer Shell: adım 6, 3 resimden 1. Removing Playstation 2 Slimline SCPH-7500x Outer Shell: adım 6, 3 resimden 2. Removing Playstation 2 Slimline SCPH-7500x Outer Shell: adım 6, 3 resimden 3.
    • Once all of the screws have been removed, pry apart the plastic covers. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate the two sides.
    • You may need to apply some gentle force to detach the covers. Be careful not to break the plastic screw pins.
  6. Removing Playstation 2 Slimline SCPH-7500x Outer Shell: adım 7, 1 resimden 1.
    • If done correctly, you should have a fully detached plastic backing, revealing the electronic components of the PlayStation 2.
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Jared Hirata
986 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-4, Regan Spring 2013 Cal Poly, Team 17-4, Regan Spring 2013 üyesi
CPSU-REGAN-S13S17G4
3 Üyeler
28 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 38
Her zaman: 3,130
