Ana içeriğe geç
Removing PowerMac G4 M5183 DVD-ROM Drive Tray
Neye ihtiyacın var
  1. Removing PowerMac G4 M5183 DVD-ROM Drive Tray, Opening PowerMac G4 M5183 Case: adım 1, 2 resimden 1. Removing PowerMac G4 M5183 DVD-ROM Drive Tray, Opening PowerMac G4 M5183 Case: adım 1, 2 resimden 2.
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Removing PowerMac G4 M5183 DVD-ROM Drive Tray, DVD-ROM Drive: adım 2, 2 resimden 1. Removing PowerMac G4 M5183 DVD-ROM Drive Tray, DVD-ROM Drive: adım 2, 2 resimden 2.
    • Removing the faceplate.
    • On the inside of the case, find the two plastic tabs.
    • While depressing the tabs, remove the faceplate by pulling and rotating outward.
  3. Removing PowerMac G4 M5183 DVD-ROM Drive Tray: adım 3, 1 resimden 1.
    • Remove the two screws on the front of the drive with the Phillips #1 screwdriver.
  4. Removing PowerMac G4 M5183 DVD-ROM Drive Tray: adım 4, 3 resimden 1. Removing PowerMac G4 M5183 DVD-ROM Drive Tray: adım 4, 3 resimden 2. Removing PowerMac G4 M5183 DVD-ROM Drive Tray: adım 4, 3 resimden 3.
    • Pull the drive out to allow access to the power and ribbon cables. Do not fully remove.
    • Remove both the power and ribbon cable.
Bitiş Çizgisi
26 farklı kişi bu kılavuzu tamamladı.
Justin Petrilli
3.132 İtibar
11 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-24, Maness Winter 2010 Cal Poly, Team 13-24, Maness Winter 2010 üyesi
CPSU-MANESS-W10S13G24
4 Üyeler
37 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 23
Her zaman: 11,088
