Ana içeriğe geç
Removing RAM from HP Elitebook 6930p
Neye ihtiyacın var
  1. Removing RAM from HP Elitebook 6930p, Battery Removal: adım 1, 3 resimden 1. Removing RAM from HP Elitebook 6930p, Battery Removal: adım 1, 3 resimden 2. Removing RAM from HP Elitebook 6930p, Battery Removal: adım 1, 3 resimden 3.
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing RAM from HP Elitebook 6930p, Keyboard: adım 2, 3 resimden 1. Removing RAM from HP Elitebook 6930p, Keyboard: adım 2, 3 resimden 2. Removing RAM from HP Elitebook 6930p, Keyboard: adım 2, 3 resimden 3.
    • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
    • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
    • Slide the retention clips toward the keyboard to release the keyboard
  3. Removing RAM from HP Elitebook 6930p: adım 3, 3 resimden 1. Removing RAM from HP Elitebook 6930p: adım 3, 3 resimden 2. Removing RAM from HP Elitebook 6930p: adım 3, 3 resimden 3.
    • Use a plastic pry tool to lift the rear edge of the keyboard.
    • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
    • Lift the keyboard up to reveal the ribbon connectors
  4. Removing RAM from HP Elitebook 6930p: adım 4, 3 resimden 1. Removing RAM from HP Elitebook 6930p: adım 4, 3 resimden 2. Removing RAM from HP Elitebook 6930p: adım 4, 3 resimden 3.
    • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
    • Release the smaller ribbon cable by lifting up the white retainer
    • I found it easier to reinstall both cables with the new keyboard resting on the back edge
  5. Removing RAM from HP Elitebook 6930p, RAM: adım 5, 2 resimden 1. Removing RAM from HP Elitebook 6930p, RAM: adım 5, 2 resimden 2.
    • Locate RAM module
    • Push metal tabs outwards away from the RAM module to release it.
    • The RAM module will spring up and can be removed from the RAM slot.
Sonuç
22 farklı kişi bu kılavuzu tamamladı.
Richdave
32.729 İtibar
30 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
329 Üyeler
1.452 adet Kılavuz yazıldı
7Kılavuz Yorumları
HP Elitebook 6930p. Huh !!!!
Desingn constructor is the largest manufacturer idiot. Put one memory slot inside, located under the keyboard denotes an unparalleled stupidity.
astorp2000 - Yanıt
I agree with above comment, weird thing to do.
S Cleaver - Yanıt
Thanks for your splendid guide. I don't have a plastic pry tool. A bass guitar plectrum works just as well though. The whole job took under 10 mins to complete. I now have X2, 2GB memory cards installed. This is plenty to run Manjaro JWM 16,04.1. It boots up only using 180 MB of RAM - perfect.
Andy Mitchell - Yanıt
Great guide. Trying to part out computer and couldn't figure out where other memory slot located. Agree dumb place for it.
Been Allison - Yanıt
the ram is acessible through the door in the middle, need to unscrew 2 screws LOL
Lukasz Nowakowski - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 58
Her zaman: 31,675
