Ana içeriğe geç
Removing Samsung DVD-P230 Motherboard
Neye ihtiyacın var
  1. Removing Samsung DVD-P230 Motherboard, Outer Cover & Faceplate: adım 1, 3 resimden 1. Removing Samsung DVD-P230 Motherboard, Outer Cover & Faceplate: adım 1, 3 resimden 2. Removing Samsung DVD-P230 Motherboard, Outer Cover & Faceplate: adım 1, 3 resimden 3.
    • Open the tray by pressing the eject button
    • Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
  2. Removing Samsung DVD-P230 Motherboard: adım 2, 1 resimden 1.
    • Press the eject button to insert the tray
    • After the tray is closed unplug DVD player
  3. Removing Samsung DVD-P230 Motherboard: adım 3, 1 resimden 1.
    • Unscrew the 3 screws in the back.
  4. Removing Samsung DVD-P230 Motherboard: adım 4, 2 resimden 1. Removing Samsung DVD-P230 Motherboard: adım 4, 2 resimden 2.
    • Pull the outer case upward and then towards you.
  5. Removing Samsung DVD-P230 Motherboard: adım 5, 3 resimden 1. Removing Samsung DVD-P230 Motherboard: adım 5, 3 resimden 2. Removing Samsung DVD-P230 Motherboard: adım 5, 3 resimden 3.
    • There are six symmetrically placed tabs holding in the front faceplate. Unhook these six tabs to loosen the faceplate.
  6. Removing Samsung DVD-P230 Motherboard: adım 6, 2 resimden 1. Removing Samsung DVD-P230 Motherboard: adım 6, 2 resimden 2.
    • Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
  7. Removing Samsung DVD-P230 Motherboard, Power Cord: adım 7, 3 resimden 1. Removing Samsung DVD-P230 Motherboard, Power Cord: adım 7, 3 resimden 2. Removing Samsung DVD-P230 Motherboard, Power Cord: adım 7, 3 resimden 3.
    • Locate the white clip that attaches the cord to the motherboard
    • Grasp clip and squeeze to release
    • Lift up and remove power cord
    • Slide cord mount from outer case
  8. Removing Samsung DVD-P230 Motherboard, Tray: adım 8, 3 resimden 1. Removing Samsung DVD-P230 Motherboard, Tray: adım 8, 3 resimden 2. Removing Samsung DVD-P230 Motherboard, Tray: adım 8, 3 resimden 3.
    • Remove the three screws holding in the DVD tray
  9. Removing Samsung DVD-P230 Motherboard: adım 9, 2 resimden 1. Removing Samsung DVD-P230 Motherboard: adım 9, 2 resimden 2.
    • Remove the power cord and first two ribbons by pulling them directly out of their sockets.
  10. Removing Samsung DVD-P230 Motherboard: adım 10, 2 resimden 1. Removing Samsung DVD-P230 Motherboard: adım 10, 2 resimden 2.
    • Gently lift the DVD tray off of the motherboard.
  11. Removing Samsung DVD-P230 Motherboard, Motherboard: adım 11, 2 resimden 1. Removing Samsung DVD-P230 Motherboard, Motherboard: adım 11, 2 resimden 2.
    • Unscrew the 2 screws on the motherboard
    • Unscrew the 2 screws on the back
  12. Removing Samsung DVD-P230 Motherboard: adım 12, 3 resimden 1. Removing Samsung DVD-P230 Motherboard: adım 12, 3 resimden 2. Removing Samsung DVD-P230 Motherboard: adım 12, 3 resimden 3.
    • Disconnect the wires and ribbon by pulling them out of their respective connections
  13. Removing Samsung DVD-P230 Motherboard: adım 13, 2 resimden 1. Removing Samsung DVD-P230 Motherboard: adım 13, 2 resimden 2.
    • Lift board up and out of the lower case
Sonuç
Bir başkası bu kılavuzu tamamladı.
Mitchell Hart
903 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-30, Regan Winter 2011 Cal Poly, Team 3-30, Regan Winter 2011 üyesi
CPSU-REGAN-W11S3G30
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 3,220
