Giriş
Follow the step-by-step instructions to remove the throttle body from the engine of a 1985-1988 Volvo 740. These instructions should be completed before performing any sort of repair.
Neye ihtiyacın var
First, disconnect the battery.
Note: Always take the negative terminal off first, then the positive terminal.
General Tip: After disconnecting the battery, let the car sit for about 10 minutes. This will allow any residual energy left in the system to settle and it is good practice for any job you are completing.
Locate the throttle body on the right side of the engine. This will be between the intake tube and the intake manifold.
Bir başkası bu kılavuzu tamamladı.
