Ana içeriğe geç
Removing the Anti-Glare Coating from a MacBook Pro Screen
Neye ihtiyacın var
  1. Removing the Anti-Glare Coating from a MacBook Pro Screen, Removing the Anti-Glare Coating from a MacBook Pro Screen: adım 1, 2 resimden 1. Removing the Anti-Glare Coating from a MacBook Pro Screen, Removing the Anti-Glare Coating from a MacBook Pro Screen: adım 1, 2 resimden 2.
    • Power off the MacBook by clicking on the Apple logo in the top left corner of the screen. Then, scroll down the list and click "Shut Down."
    • Disconnect any attached cables such as chargers or wired headphones.
    • Disconnecting cables before beginning this repair is crucial to avoid moisture damage and electrical shocks. Cables should not be present in order to fully clean the ports and connectors.
  2. Removing the Anti-Glare Coating from a MacBook Pro Screen: adım 2, 2 resimden 1. Removing the Anti-Glare Coating from a MacBook Pro Screen: adım 2, 2 resimden 2.
    • Gently wipe the screen's surface with either a microfiber cloth or cotton pad to remove any residual dust or oil.
  3. Removing the Anti-Glare Coating from a MacBook Pro Screen: adım 3, 1 resimden 1.
    • Apply a mild plastic polish or cleaning solution like Bar Keeper’s Friend (liquid) to a cotton pad.
  4. Removing the Anti-Glare Coating from a MacBook Pro Screen: adım 4, 2 resimden 1. Removing the Anti-Glare Coating from a MacBook Pro Screen: adım 4, 2 resimden 2.
    • Softly rub the coating from the cotton pad onto the MacBook's screen in small circular motions.
    • Be careful not to damage the screen underneath.
  5. Removing the Anti-Glare Coating from a MacBook Pro Screen: adım 5, 1 resimden 1.
    • Wipe the screen clean with a new microfiber cloth or cotton pad. Inspect for remaining coating.
    • If the damaged anti-glare coating still remains, repeat this process as many times as needed.
Bitiş Çizgisi
Nicole Vo
121 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 1-4, Whithaus Spring 2025 UC Davis, Team 1-4, Whithaus Spring 2025 üyesi
UCD-WHITHAUS-S25S1G4
3 Üyeler
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 24
Son 30 gün: 114
Her zaman: 476
