Ana içeriğe geç
Removing the Apple Cinema Display M8149 Display Hinge
Neye ihtiyacın var
  1. Removing the Apple Cinema Display M8149 Display Hinge, Display Hinge: adım 1, 3 resimden 1. Removing the Apple Cinema Display M8149 Display Hinge, Display Hinge: adım 1, 3 resimden 2. Removing the Apple Cinema Display M8149 Display Hinge, Display Hinge: adım 1, 3 resimden 3.
    • Before starting, make sure the display is UNPLUGGED. Failure to do so can result in shock and serious injury.
    • Flip the Cinema Display so it is on its face and the feet are pointed away from you.
    • Using the PH 2 screwdriver, unscrew the three feet screws (9.52 x 4.43 mm).
    • Remove the back foot from the hinge mount by gently pulling it upwards.
  2. Removing the Apple Cinema Display M8149 Display Hinge: adım 2, 3 resimden 1. Removing the Apple Cinema Display M8149 Display Hinge: adım 2, 3 resimden 2. Removing the Apple Cinema Display M8149 Display Hinge: adım 2, 3 resimden 3.
    • Remove the back plate screws (5.25 x 4.43 mm) using the PH 2 screw driver.
    • Lift the back plate off of the display.
    • Completely remove the back plate and set it aside.
  3. Removing the Apple Cinema Display M8149 Display Hinge: adım 3, 2 resimden 1. Removing the Apple Cinema Display M8149 Display Hinge: adım 3, 2 resimden 2.
    • Remove the Apple Display Connector plate screws (9.52 x 3.43 mm) with the PH 2 screwdriver.
    • Once the two screws have been removed, move the cord out of the way.
  4. Removing the Apple Cinema Display M8149 Display Hinge: adım 4, 3 resimden 1. Removing the Apple Cinema Display M8149 Display Hinge: adım 4, 3 resimden 2. Removing the Apple Cinema Display M8149 Display Hinge: adım 4, 3 resimden 3.
    • Remove the hinge plate screws (5.52 x 3.43 mm) with the PH 2 screw driver.
    • Then lift out the hinge mount.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Thomas Harper
244 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 10-41, Forte Spring 2011 Cal Poly, Team 10-41, Forte Spring 2011 üyesi
CPSU-FORTE-S11S10G41
5 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 19
Her zaman: 7,616
