Ana içeriğe geç
Removing the Back Panel
Neye ihtiyacın var
  1. Removing the Back Panel, Removing the Back Panel: adım 1, 3 resimden 1. Removing the Back Panel, Removing the Back Panel: adım 1, 3 resimden 2. Removing the Back Panel, Removing the Back Panel: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Place the tablet face down on a soft, stable surface that will protect the screen.
    • Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
    • Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
    • If the seal covering the screw has already been removed, please proceed to the next step in the process.
    • As the screw is small, you may wish to extract it using a pair of tweezers.
    FixBot'a Sor
    Yorum Ekle
  2. Removing the Back Panel: adım 2, 3 resimden 1. Removing the Back Panel: adım 2, 3 resimden 2. Removing the Back Panel: adım 2, 3 resimden 3.
    • Starting on the side, work your way around the the tablet to pop off the back cover. You will want to utilize a metal Spudger for this.
    • Some force may be required initially to pry the back cover off.
    • Note that the button tabs for this device are loose inside the case and will fall out when opening.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 43
Her zaman: 3,025
