Ana içeriğe geç
Tehlike
Tehlikeli Olma Potansiyeli Var
Bu talimat doğru şekilde uygulanmazsa yaralanma meydana gelebilir. Dikkatli olun ve tüm uyarıları takip edin.
Tehlike
Giriş
Your B212D contains a case filled with a metal box that contains all the electronics, except for the speakers. You will be removing this electronics box to access the case's internal space - you know, in case you need to stash $1,000,000 dollars in there to hide it from the CIA! :)
Parçalar
Hiçbir parça belirtilmedi.
  1. CAUTION: Unplug your speaker from the power outlet.
    • CAUTION: Unplug your speaker from the power outlet.
    • Remove the 8 Phillips screws from the back of the speaker.
  2. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  3. Carefully remove the back panel, lifting out the metal electronics-box with it.
    • Carefully remove the back panel, lifting out the metal electronics-box with it.
    • To avoid damaging your speaker, remove slowly, as there is still a wire attached from the electronics box to the speaker.
Sonuç
Bir başkası bu kılavuzu tamamladı.
gameslammer7
888 İtibar
6 adet Kılavuz yazıldı
2 Yorum
I want to buy the hole back panel, but I don't where?, tell me
miguelangelvera63 - Yanıt
I will wait for answer
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 Gün: 6
Son 30 Gün: 32
Her zaman: 2,431
