Ana içeriğe geç
Removing the Dell Inspiron 1150 Modem Card
Neye ihtiyacın var
  1. Removing the Dell Inspiron 1150 Modem Card, Battery: adım 1, 3 resimden 1. Removing the Dell Inspiron 1150 Modem Card, Battery: adım 1, 3 resimden 2. Removing the Dell Inspiron 1150 Modem Card, Battery: adım 1, 3 resimden 3.
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Removing the Dell Inspiron 1150 Modem Card, Modem Card: adım 2, 3 resimden 1. Removing the Dell Inspiron 1150 Modem Card, Modem Card: adım 2, 3 resimden 2. Removing the Dell Inspiron 1150 Modem Card, Modem Card: adım 2, 3 resimden 3.
    • Turn the laptop upside down and locate the panel labeled C
    • Unscrew the single screw holding the cover in place.
    • Lift up the cover and remove it to expose the Modem Card.
  3. Removing the Dell Inspiron 1150 Modem Card: adım 3, 2 resimden 1. Removing the Dell Inspiron 1150 Modem Card: adım 3, 2 resimden 2.
    • Locate the Modem card.
    • Remove the screws.
  4. Removing the Dell Inspiron 1150 Modem Card: adım 4, 2 resimden 1. Removing the Dell Inspiron 1150 Modem Card: adım 4, 2 resimden 2.
    • Pull tab to lift the card out of the connector on the main board.
    • Disconnect the cable attached to the left edge of the Modem card
Bitiş Çizgisi
Lauren
4 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 16-2, Maness Spring 2010 Cal Poly, Team 16-2, Maness Spring 2010 üyesi
CPSU-MANESS-S10S16G2
4 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 28
Her zaman: 4,577
