Ana içeriğe geç
Removing the Dell Inspiron 1150 Optical Drive (Based on Dell Manual)
Neye ihtiyacın var
  1. Removing the Dell Inspiron 1150 Optical Drive (Based on Dell Manual), Removing Dell Inspiron 1150 Battery: adım 1, 3 resimden 1. Removing the Dell Inspiron 1150 Optical Drive (Based on Dell Manual), Removing Dell Inspiron 1150 Battery: adım 1, 3 resimden 2. Removing the Dell Inspiron 1150 Optical Drive (Based on Dell Manual), Removing Dell Inspiron 1150 Battery: adım 1, 3 resimden 3.
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Removing the Dell Inspiron 1150 Optical Drive (Based on Dell Manual), Optical Drive (Based on Dell Service Manual): adım 2, 3 resimden 1. Removing the Dell Inspiron 1150 Optical Drive (Based on Dell Manual), Optical Drive (Based on Dell Service Manual): adım 2, 3 resimden 2. Removing the Dell Inspiron 1150 Optical Drive (Based on Dell Manual), Optical Drive (Based on Dell Service Manual): adım 2, 3 resimden 3.
    • Place laptop upsid down on a clean flat work surface.
    • Remove the Philips M2.5 x 8 mm screw
    • Loosen the screw that holds the memory compartment closed
    • remove the memory module compartment cover
    • Press the Optical Drive release lever to the right and the optical drive should slide out of the case
Sonuç
Richdave
32.063 İtibar
30 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.528 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 509
