Ana içeriğe geç
Removing the HP Compaq dx2000MT Optical (CD) Drive
Neye ihtiyacın var
  1. Removing the HP Compaq dx2000MT Optical (CD) Drive, Removing the HP Compaq dx2000MT Case Doors: adım 1, 1 resimden 1.
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Removing the HP Compaq dx2000MT Optical (CD) Drive: adım 2, 2 resimden 1. Removing the HP Compaq dx2000MT Optical (CD) Drive: adım 2, 2 resimden 2.
    • Remove the two Phillips #2 screws that secure the case door to the device.
  3. Removing the HP Compaq dx2000MT Optical (CD) Drive: adım 3, 3 resimden 1. Removing the HP Compaq dx2000MT Optical (CD) Drive: adım 3, 3 resimden 2. Removing the HP Compaq dx2000MT Optical (CD) Drive: adım 3, 3 resimden 3.
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Removing the HP Compaq dx2000MT Optical (CD) Drive: adım 4, 3 resimden 1. Removing the HP Compaq dx2000MT Optical (CD) Drive: adım 4, 3 resimden 2. Removing the HP Compaq dx2000MT Optical (CD) Drive: adım 4, 3 resimden 3.
    • Once again, this may take considerable force.
  5. Removing the HP Compaq dx2000MT Optical (CD) Drive, Optical (CD) Drive: adım 5, 3 resimden 1. Removing the HP Compaq dx2000MT Optical (CD) Drive, Optical (CD) Drive: adım 5, 3 resimden 2. Removing the HP Compaq dx2000MT Optical (CD) Drive, Optical (CD) Drive: adım 5, 3 resimden 3.
    • Remove the IDE data cable and the power cable from the optical drive by pulling away from the drive.
  6. Removing the HP Compaq dx2000MT Optical (CD) Drive: adım 6, 2 resimden 1. Removing the HP Compaq dx2000MT Optical (CD) Drive: adım 6, 2 resimden 2.
    • Remove the 2 Torx T15 screws holding the optical drive in place.
  7. Removing the HP Compaq dx2000MT Optical (CD) Drive: adım 7, 2 resimden 1. Removing the HP Compaq dx2000MT Optical (CD) Drive: adım 7, 2 resimden 2.
    • Remove the other 2 Torx T15 screws holding the other side of the drive in place.
  8. Removing the HP Compaq dx2000MT Optical (CD) Drive: adım 8, 3 resimden 1. Removing the HP Compaq dx2000MT Optical (CD) Drive: adım 8, 3 resimden 2. Removing the HP Compaq dx2000MT Optical (CD) Drive: adım 8, 3 resimden 3.
    • Remove the optical drive by sliding it out the front of the device.
Sonuç
Logan Pace
2.224 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-16, Regan Fall 2011 Cal Poly, Team 17-16, Regan Fall 2011 üyesi
CPSU-REGAN-F11S17G16
4 Üyeler
17 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 1,468
