Ana içeriğe geç
Removing the HP Elitebook 6930p Bluetooth module
Neye ihtiyacın var
  1. Removing the HP Elitebook 6930p Bluetooth module, Battery Removal: adım 1, 3 resimden 1. Removing the HP Elitebook 6930p Bluetooth module, Battery Removal: adım 1, 3 resimden 2. Removing the HP Elitebook 6930p Bluetooth module, Battery Removal: adım 1, 3 resimden 3.
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing the HP Elitebook 6930p Bluetooth module, Bluetooth module: adım 2, 3 resimden 1. Removing the HP Elitebook 6930p Bluetooth module, Bluetooth module: adım 2, 3 resimden 2. Removing the HP Elitebook 6930p Bluetooth module, Bluetooth module: adım 2, 3 resimden 3.
    • Locate the Bluetooth module cover on the bottom of the laptop
    • Loosen the M2.0×5.0 captive screw and remove the cover by by lifting it straight up
    • The Bluetooth module is connected to the laptop via a small cable with very fine wires - take care not to damage the cable when you pull the module out of the case.
    • Gently lift the Bluetooth module up and over the retaining clip. A plastic spudger may be useful.
    • Disconnect the connector being careful not to damage the fine wires on the cable.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Richdave
32.413 İtibar
30 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
327 Üyeler
1.673 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 19
Her zaman: 5,220
