Ana içeriğe geç
Removing the HP Elitebook 6930p Switch Cover
Neye ihtiyacın var
  1. Removing the HP Elitebook 6930p Switch Cover, Battery Removal: adım 1, 3 resimden 1. Removing the HP Elitebook 6930p Switch Cover, Battery Removal: adım 1, 3 resimden 2. Removing the HP Elitebook 6930p Switch Cover, Battery Removal: adım 1, 3 resimden 3.
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing the HP Elitebook 6930p Switch Cover, Keyboard: adım 2, 3 resimden 1. Removing the HP Elitebook 6930p Switch Cover, Keyboard: adım 2, 3 resimden 2. Removing the HP Elitebook 6930p Switch Cover, Keyboard: adım 2, 3 resimden 3.
    • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
    • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
    • Slide the retention clips toward the keyboard to release the keyboard
  3. Removing the HP Elitebook 6930p Switch Cover: adım 3, 3 resimden 1. Removing the HP Elitebook 6930p Switch Cover: adım 3, 3 resimden 2. Removing the HP Elitebook 6930p Switch Cover: adım 3, 3 resimden 3.
    • Use a plastic pry tool to lift the rear edge of the keyboard.
    • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
    • Lift the keyboard up to reveal the ribbon connectors
  4. Removing the HP Elitebook 6930p Switch Cover: adım 4, 3 resimden 1. Removing the HP Elitebook 6930p Switch Cover: adım 4, 3 resimden 2. Removing the HP Elitebook 6930p Switch Cover: adım 4, 3 resimden 3.
    • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
    • Release the smaller ribbon cable by lifting up the white retainer
    • I found it easier to reinstall both cables with the new keyboard resting on the back edge
  5. Removing the HP Elitebook 6930p Switch Cover, Switch Cover: adım 5, 3 resimden 1. Removing the HP Elitebook 6930p Switch Cover, Switch Cover: adım 5, 3 resimden 2. Removing the HP Elitebook 6930p Switch Cover, Switch Cover: adım 5, 3 resimden 3.
    • Remove the two M2.0×4.0 broad-head screws.
    • Remove the three Torx T8 M2.5×7.0 screws.
  6. Removing the HP Elitebook 6930p Switch Cover: adım 6, 3 resimden 1. Removing the HP Elitebook 6930p Switch Cover: adım 6, 3 resimden 2. Removing the HP Elitebook 6930p Switch Cover: adım 6, 3 resimden 3.
    • Turn the computer over with the front toward you and the open the computer as far as possible.
    • Release the ZIF connector for the power button board cable.
    • Remove the switch cover by lifting it straight up and flip it forward.
    • Release the ZIF connector for the LED board cable.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Richdave
32.413 İtibar
30 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
327 Üyeler
1.673 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 28
Her zaman: 2,038
