Ana içeriğe geç
Removing the HP Elitebook 6930p WLAN Module
Neye ihtiyacın var
  1. Removing the HP Elitebook 6930p WLAN Module, Battery Removal: adım 1, 3 resimden 1. Removing the HP Elitebook 6930p WLAN Module, Battery Removal: adım 1, 3 resimden 2. Removing the HP Elitebook 6930p WLAN Module, Battery Removal: adım 1, 3 resimden 3.
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing the HP Elitebook 6930p WLAN Module, Keyboard: adım 2, 3 resimden 1. Removing the HP Elitebook 6930p WLAN Module, Keyboard: adım 2, 3 resimden 2. Removing the HP Elitebook 6930p WLAN Module, Keyboard: adım 2, 3 resimden 3.
    • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
    • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
    • Slide the retention clips toward the keyboard to release the keyboard
  3. Removing the HP Elitebook 6930p WLAN Module: adım 3, 3 resimden 1. Removing the HP Elitebook 6930p WLAN Module: adım 3, 3 resimden 2. Removing the HP Elitebook 6930p WLAN Module: adım 3, 3 resimden 3.
    • Use a plastic pry tool to lift the rear edge of the keyboard.
    • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
    • Lift the keyboard up to reveal the ribbon connectors
  4. Removing the HP Elitebook 6930p WLAN Module: adım 4, 3 resimden 1. Removing the HP Elitebook 6930p WLAN Module: adım 4, 3 resimden 2. Removing the HP Elitebook 6930p WLAN Module: adım 4, 3 resimden 3.
    • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
    • Release the smaller ribbon cable by lifting up the white retainer
    • I found it easier to reinstall both cables with the new keyboard resting on the back edge
  5. Removing the HP Elitebook 6930p WLAN Module, WLAN (WiFi) Module: adım 5, 3 resimden 1. Removing the HP Elitebook 6930p WLAN Module, WLAN (WiFi) Module: adım 5, 3 resimden 2. Removing the HP Elitebook 6930p WLAN Module, WLAN (WiFi) Module: adım 5, 3 resimden 3.
    • Locate the WLAN module
    • Use a plastic spugder or similar to carefully remove the 3 antenna wires from the WLAN module.
    • The antenna wires are colour coded tabs on them for easy reinstallation so be sure to take note of the correct order. there are coloured tabs on the wires!
    • Remove the 2 M2.5×4.0 screws that secure the WLAN module into the laptop
    • With the screws removed the right hand end of the WLAN module will pop up. You may now simply remove the module from the edge connector.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Richdave
32.413 İtibar
30 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
327 Üyeler
1.672 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 24
Her zaman: 8,319
