Ana içeriğe geç
Removing the HP Elitebook 6930p modem card
Neye ihtiyacın var
  1. Removing the HP Elitebook 6930p modem card, Battery Removal: adım 1, 3 resimden 1. Removing the HP Elitebook 6930p modem card, Battery Removal: adım 1, 3 resimden 2. Removing the HP Elitebook 6930p modem card, Battery Removal: adım 1, 3 resimden 3.
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing the HP Elitebook 6930p modem card, Keyboard: adım 2, 3 resimden 1. Removing the HP Elitebook 6930p modem card, Keyboard: adım 2, 3 resimden 2. Removing the HP Elitebook 6930p modem card, Keyboard: adım 2, 3 resimden 3.
    • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
    • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
    • Slide the retention clips toward the keyboard to release the keyboard
  3. Removing the HP Elitebook 6930p modem card: adım 3, 3 resimden 1. Removing the HP Elitebook 6930p modem card: adım 3, 3 resimden 2. Removing the HP Elitebook 6930p modem card: adım 3, 3 resimden 3.
    • Use a plastic pry tool to lift the rear edge of the keyboard.
    • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
    • Lift the keyboard up to reveal the ribbon connectors
  4. Removing the HP Elitebook 6930p modem card: adım 4, 3 resimden 1. Removing the HP Elitebook 6930p modem card: adım 4, 3 resimden 2. Removing the HP Elitebook 6930p modem card: adım 4, 3 resimden 3.
    • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
    • Release the smaller ribbon cable by lifting up the white retainer
    • I found it easier to reinstall both cables with the new keyboard resting on the back edge
  5. Removing the HP Elitebook 6930p modem card, Modem card: adım 5, 2 resimden 1. Removing the HP Elitebook 6930p modem card, Modem card: adım 5, 2 resimden 2.
    • Locate the modem card and remove the 2 M2.5×4.0 screws
    • The modem card is it is plugged into a connector on the logic board. Gently lift the card up and out of the laptop
    • A plastic spudger may be useful in lifting the card out
    • Be careful as there is a small cable connected to the edge of the modem card closest to the LCD display
    • Disconnect the cable from the modem card to complete removal
Sonuç
Bir başkası bu kılavuzu tamamladı.
Richdave
32.063 İtibar
30 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.528 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 1,385
