Ana içeriğe geç
Giriş
You will learn how to remove scroll wheel from the wheel mount.
Parçalar
Hiçbir parça belirtilmedi.
  1. Hold the mouse so that the bottom is facing up.
    • Hold the mouse so that the bottom is facing up.
    • Locate the #1 screw towards the bottom half of the mouse.
    • Take the 4.76 mm Phillips screwdriver and unscrew the #1 screw.
    باز کردن پیچ زیر موس
    h sh - Yanıt
  2. Place the mouse so that the bottom is resting against a hard surface . Gently lift the top cover of the mouse and remove.
    • Place the mouse so that the bottom is resting against a hard surface .
    • Gently lift the top cover of the mouse and remove.
    جدا کردن قاب رو و زیر موس
    h sh - Yanıt
  3. Dizüstü Bilgisayar Bataryaları
    An easy fix for a big power boost.
    Hemen Alışveriş Yapın
  4. Locate the scroll wheel on the mouse. Grab the scroll wheel with your thumb and index finger. Gently lift up to remove the scroll wheel from the mouse.
    • Locate the scroll wheel on the mouse.
    • Grab the scroll wheel with your thumb and index finger.
    • Gently lift up to remove the scroll wheel from the mouse.
    خارج کردن چرخ اسکرول موس
    h sh - Yanıt
  5. Locate the spring on the scroll wheel. The spring is a small piece of metal wire coiled in the middle. Carefully remove the spring from the wheel scroll.
    • Locate the spring on the scroll wheel. The spring is a small piece of metal wire coiled in the middle.
    • Carefully remove the spring from the wheel scroll.
    نحوه قرارگیری فنر سمت راست چرخ اسکرول
    h sh - Yanıt
  6. Replace the spring, place it on the correct side of the wheel with the prongs pointing down. The correct side is the side without the black plastic square, as shown in the photos.
    • Replace the spring, place it on the correct side of the wheel with the prongs pointing down.
    • The correct side is the side without the black plastic square, as shown in the photos.
    h sh - Yanıt
  7. Locate the black wheel mount. Note: Make sure that the spring hidden in the mount does not fall out. Separate the wheel from its mount.
    • Locate the black wheel mount.
    • Note: Make sure that the spring hidden in the mount does not fall out.
    • Separate the wheel from its mount.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Conor Whatley
345 İtibar
3 adet Kılavuz yazıldı
Takım
Cal Poly, Team 5-14, Forte Winter 2013 Cal Poly, Team 5-14, Forte Winter 2013 üyesi
CPSU-FORTE-W13S5G14
5 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
Thank you! The photographs with good resolution and correct lighting made everything clear and comprehencible.
Антон Вакаренко - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 1
Son 30 Gün: 7
Her zaman: 1,033
