Ana içeriğe geç
Removing the Phone Keypad
Neye ihtiyacın var
  1. Removing the Phone Keypad, Removing the Back Panel: adım 1, 2 resimden 1. Removing the Phone Keypad, Removing the Back Panel: adım 1, 2 resimden 2.
    • Orient the phone so that the phone model and other descriptive information is facing upward.
    • Locate the two silver screws near the hinge where the battery is housed.
    • Remove the silver screws using a Phillips head #2 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Removing the Phone Keypad: adım 2, 3 resimden 1. Removing the Phone Keypad: adım 2, 3 resimden 2. Removing the Phone Keypad: adım 2, 3 resimden 3.
    • Pull off the back panel of the phone.
    • Make sure you pull the cover off carefully in order to prevent damage to the back cover.
    FixBot'a Sor
    Yorum Ekle
  3. Removing the Phone Keypad, Keypad: adım 3, 2 resimden 1. Removing the Phone Keypad, Keypad: adım 3, 2 resimden 2.
    • Locate and unscrew the circled screw using a Philips head #2 screw driver or screw driver head.
    FixBot'a Sor
    Yorum Ekle
  4. Removing the Phone Keypad: adım 4, 1 resimden 1.
    • Lift the motherboard away from the phone housing.
    • Be careful when lifting the motherboard. To prevent damage to the motherboard, gradually lift it from its place in the assembly.
    FixBot'a Sor
    Yorum Ekle
  5. Removing the Phone Keypad: adım 5, 2 resimden 1. Removing the Phone Keypad: adım 5, 2 resimden 2.
    • Now that the motherboard has been lifted out of place, the keypad can be accessed.
    • Using your fingers push the buttons from the the phone toward the lifted motherboard.
    • Remove the keypad from the assembly.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Elizabeth Kelly
501 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 15-1, Benson Fall 2012 Clemson, Team 15-1, Benson Fall 2012 üyesi
CLEM-BENSON-F12S15G1
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 36
Her zaman: 1,409
