Ana içeriğe geç
Removing the Samsung LA40R81BD 40in LCD TV Power Supply Board
Neye ihtiyacın var
  1. Removing the Samsung LA40R81BD 40in LCD TV Power Supply Board, Rear Cover: adım 1, 1 resimden 1.
    • Unplug power cable and all AV cables from rear of TV and carefully lay TV face down on a clean flat working surface ensuring that you don't damage the LCD screen.
    • Using a Philips driver remove the 18 screws from the rear panel.
    • Gently lift the rear cover off the TV. You may need to wiggle the cover a little however there are no clips holding the cover on so it should come off easily if you have fully unscrewed all 18 screws.
  2. Removing the Samsung LA40R81BD 40in LCD TV Power Supply Board, Power Supply Board: adım 2, 1 resimden 1.
    • Remove the 7 connectors from the board
    • Remove the 7 screws from the board
    • Lift the main board away from the chassis ensuring you don's snag or catch any of the cables.
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
Richdave
32.063 İtibar
30 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.528 adet Kılavuz yazıldı
2 Yorum
Ma télé LCD Samsung ne veule pas s allume pas de courant que dois je faire s.v.p
Samir Chaaraoui - Yanıt
Vielen Dank für Ihren Artikel. Das Ausstecken ist für mich jetzt einfacher geworden! Ich hoffe, Sie können eine Anleitung zum Entfernen des Netzteils mit dem incredibox-Gerät geben.
Lily Collins - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 34
Her zaman: 7,558
