Neye ihtiyacın var
Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
In order to remove the fan blade, use pliers to remove the holding nut.
After the holding nut is loose, use the pliers to pull up to remove the nut.
Sonuç
2Kılavuz Yorumları
Donde compró el transformador para ventilador servilletas Classics MSC10166
Deseo comprar el transformador para ventilador serville
