Ana içeriğe geç
Removinging Panasonic DVD-RV31 Player Rear Panel
Neye ihtiyacın var
  1. Removinging Panasonic DVD-RV31 Player Rear Panel, Outer Case: adım 1, 2 resimden 1. Removinging Panasonic DVD-RV31 Player Rear Panel, Outer Case: adım 1, 2 resimden 2.
    • Remove the three screws running along the back edge of case cover.
    • Remove the two screws from each side of the case cover.
  2. Removinging Panasonic DVD-RV31 Player Rear Panel: adım 2, 1 resimden 1.
    • Grab edges of the cover with your hands. Pull outward slightly, then straight up.
  3. Removinging Panasonic DVD-RV31 Player Rear Panel, Rear Panel: adım 3, 2 resimden 1. Removinging Panasonic DVD-RV31 Player Rear Panel, Rear Panel: adım 3, 2 resimden 2.
    • Be sure case cover has been removed prior to back panel removal.
    • Remove 5 screws from panel, as shown.
  4. Removinging Panasonic DVD-RV31 Player Rear Panel: adım 4, 2 resimden 1. Removinging Panasonic DVD-RV31 Player Rear Panel: adım 4, 2 resimden 2.
    • Use flat-head screwdriver to push in square tabs, located on each side of the back panel.
    • Use caution, the edges are sharp.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kevin
375 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-20, Garner Spring 2011 Cal Poly, Team 18-20, Garner Spring 2011 üyesi
CPSU-GARNER-S11S18G20
4 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 17
Her zaman: 2,313
