Ana içeriğe geç
SodaStream Source Battery Replacement
Neye ihtiyacın var
  1. SodaStream Source Battery Replacement, SodaStream Source External Disassembly: adım 1, 3 resimden 1. SodaStream Source Battery Replacement, SodaStream Source External Disassembly: adım 1, 3 resimden 2. SodaStream Source Battery Replacement, SodaStream Source External Disassembly: adım 1, 3 resimden 3.
    • Remove the soda bottle and the CO₂ canister from the machine.
  2. SodaStream Source Battery Replacement: adım 2, 2 resimden 1. SodaStream Source Battery Replacement: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    Phillips #1 Screwdriver
    $8.99
  3. SodaStream Source Battery Replacement: adım 3, 2 resimden 1. SodaStream Source Battery Replacement: adım 3, 2 resimden 2.
    • Pull the outer cover away from the front of the device.
  4. SodaStream Source Battery Replacement: adım 4, 1 resimden 1.
    $8.99
  5. SodaStream Source Battery Replacement: adım 5, 2 resimden 1. SodaStream Source Battery Replacement: adım 5, 2 resimden 2.
    Jimmy
    $7.95
    • Firmly pull the front cover off.
    • This piece is difficult to remove and requires force. It may help to use a wide, thin object to pry it off (like a Jimmy).
  6. SodaStream Source Battery Replacement, Battery: adım 6, 2 resimden 1. SodaStream Source Battery Replacement, Battery: adım 6, 2 resimden 2.
    • Remove the old battery and replace it with a new 3V lithium battery.
Sonuç
28 farklı kişi bu kılavuzu tamamladı.
Alexandra I Curtis
1.091 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G4, Leahy Spring 2017 USF Tampa, Team S1-G4, Leahy Spring 2017 üyesi
USFT-LEAHY-S17S1G4
3 Üyeler
41 adet Kılavuz yazıldı
22Kılavuz Yorumları
Heel de achterkant hoeft er hiervoor niet af hoor juist de voorkant 2 vijsjes en je kan het voorste deksel er af klikken ;)
tomclaes1989 - Yanıt
Perfectly explained! I was afraid to pull the front cover because it does indeed take a lot of force to pull off!!
its important to note it’s a C123A 3v battery, not the C2 3v as I found out after opening
Kevin Shiner - Yanıt
Where is the best place to find these batteries? Canadian tire?
Dancingdaisy007 S -
Its the same battery many many products use usually built in , motherboards used it for years.
Kal Jak -
Staples has the 123A 3v battery
scottvelasco - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 25
Son 7 gün: 193
Son 30 gün: 988
Her zaman: 111,205
