Giriş
Ce tutoriel vous explique comment remplacer la batterie de la PlayStation Vita.
Neye ihtiyacın var
Avec un tournevis cruciforme Phillips #00, dévissez les quatre vis 6,4 mm sur le boîtier arrière.
À l'aide d'une spatule, faites délicatement levier et retirez le dispositif de retenue du câble de batterie sur le boîtier arrière.
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
127 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
27 Yorum
Great guide. Only problem is this takes very steady hands (something i do not have)
This is a great guide. It allowed me to execute the repair and do so without and damage. Just be careful with the triggers they can move and get caught while closing everything up.
Jewon today we have a hack for psvita 3.60 version ONLY !! this allow u download a VPK file that says how much persent your battery is at
With your Vita connected to your PC and the Content manager application running, on windows right click on the vita and then properties and the battery percentage will show up.
