Ana içeriğe geç
Remplacement des piles du clavier sans fil d'Apple
Neye ihtiyacın var
  1. Remplacement des piles du clavier sans fil d'Apple, Piles: adım 1, 1 resimden 1.
    • Utilisez une pièce de monnaie pour enlever le couvercle du compartiment où se trouvent les piles.
    What if solidly stuck? No way then to change battery it needs active.
    Sherry Lowry - Yanıt
  2. Remplacement des piles du clavier sans fil d'Apple: adım 2, 2 resimden 1. Remplacement des piles du clavier sans fil d'Apple: adım 2, 2 resimden 2.
    • Faites glisser les deux piles AA du compartiment. Vérifiez que les bornes positives et négatives soient dans le bon sens.
    Question-how can I identify age of keyboard? I have it 7+ Year’s. Keyboard isn’t responding. Trying to change Batteries-I am able to ck 2 Batteries which are chgd. But it looks like it has another one but I can not get it out….any suggestions?
    Carol Ann - Yanıt
    HELP ME PLEASE
    Carol Ann
    Carol Ann - Yanıt
Sonuç
Pour réassembler votre appareil, suivez les instructions dans le sens inverse.
35 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
en fr
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
rab777hp
20.333 İtibar
3 adet Kılavuz yazıldı
Ekip
OPEN OPEN üyesi
Community
82 Üyeler
25 adet Kılavuz yazıldı
5 Yorum
This works great - as long as the batteries inside did not leak and create a permanent seal for the cap. I managed to get the keyboard working again by removing the batteries through the electronics compartment (remove grey center cover, slide electronics out). It did take some effort (including driving a screw into the stuck battery and yanking it out with pliers) to remove the stuck batteries and all the remains of the leakage, but I ended up with a working keyboard. Only thing is that I need to use the 'backdoor' every time my batteries need replacing, since the battery cover is permanently sealed...
Otto - Yanıt
Also have a perma sealed battery cover. Poured vinegar in from middle and let soak over night. Wanna drill into coin slot to try and remove cover but need to get batteries out first. Can I just remove the one screw from logic board and disconnect ribbon cable, to have it slide out the power button end? How careful w cable? Looks like it has 2 tiny clips, do these need to be addressed or can I just pry it off?
William Shouse -
Warm the area where battery screw cover is in a stream of hot water from the faucet. Be careful not to get water into the keyboard or keys. The warmth will sometimes expand the aluminum enough to loosen the screw cover. Worked for mine.
Greg M - Yanıt
Thanks!
worked well. Had to push old battery out from electronics cover area. Keyboard working again :)
tankapoet - Yanıt
It’s possible, but how can I get it? I am in somali country please help me
saalix49 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 14
Son 7 gün: 91
Son 30 gün: 471
Her zaman: 98,342
