Giriş
Un guide pour retirer le bloc d'alimentation de Sega Dreamcast.
Neye ihtiyacın var
Retournez la console à l'envers.
Prenez note de votre numéro de model, au cas ou une pièce de rechange est nécessaire.
Repérez et retirez les quatre vis cruciformes noir n° 02 de l’autre côté de la console.
Retirez la prise femelle blanche en serrant le clip et en le tirant doucement de la carte électronique de puissance.
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
8 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
Brendan dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
3 Yorum
All symptoms of dead PSU can be occuring, if by accident flat ribbon cable between motherboard and controller board is disconnected. Check that cable if both ends is firmly plugged.
Hello There!
i turn on my dreamcast, No video, GD don´t spin, but the orange led barely shine, this happened many years ago (2003) , i just bought another DC in those days because i was in a hurry to end Grandia 2, and now i still have the damaged console in my room and im wondering if it is possible to fix it ...thanks!
