Ana içeriğe geç
Remplacement du panneau arrière sur Dell XPS 13 9380
Neye ihtiyacın var
  1. Remplacement du panneau arrière sur Dell XPS 13 9380, Retirer le panneau arrière: adım 1, 3 resimden 1. Remplacement du panneau arrière sur Dell XPS 13 9380, Retirer le panneau arrière: adım 1, 3 resimden 2. Remplacement du panneau arrière sur Dell XPS 13 9380, Retirer le panneau arrière: adım 1, 3 resimden 3.
    • Dévisser les huit vis (Torx M2x3) qui fixent le panneau arrière.
    • Retournez l’ordinateur, puis ouvrez-le en l’inclinant.
    • À l'aide d'un Spudger, faites levier sur le panneau arrière.
    • En faisant glisser le panneau arrière de gauche à droite, libérez les clips qui le fixent. Vous pouvez ainsi le retirer.
    You should be careful when removing the back panel as there also two clips on its back where the air ducts lie. If you are quick to remove it you may tear the air ducts which are quite (unreasonably) fragile given the fact they are plastic. I was unfortunate and I broke two of them so I had to use some duct tape as a minor gap would be visible between the back panel and the plastically covered air ducts. Other than that, it’s a pain to remove the back panel but not as difficult as it sounds.
    Iraklis - Yanıt
Sonuç
Pour réassembler votre appareil, suivez les instructions dans l'ordre inverse.
Bir başkası bu kılavuzu tamamladı.
Schwarzer
4.844 İtibar
13 adet Kılavuz yazıldı
Ekip
i.Fixit FR Team i.Fixit FR Team üyesi
Community
3 Üyeler
40 adet Kılavuz yazıldı
Bir Yorum
The torx bit used is a T5, the screw is an m2x3 — if you’re buying a kit you want the T5 torx bit
swosse - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 59
Her zaman: 4,410
