Giriş
From use and abuse, the bottoms of the mouse buttons can wear down and become unable to click the digital buttons inside the mouse.
Neye ihtiyacın var
Flip the mouse over and peel off the stickers on the perimeter of the bottom of the mouse.
Remove the 5 mm round head screw holding the middle piece to the top piece.
The outermost shell will now separate from the middle structure.
Take the plastic buttons (the part that your fingers click) and flip them over.
On the bottom, there should be little plastic towers. Wearing these down can prevent the buttons from clicking properly.
File the bottoms of these towers flat to remove any ridges that prevent proper clicking.
Make sure to file down both towers. In this image, one is left un-filed to show the difference.
This process can also be used for the other buttons on the mouse. Use other guides to disassemble the mouse until the desired button is accessible, and then perform the same filing technique.
20 farklı kişi bu kılavuzu tamamladı.
16Kılavuz Yorumları
Really a great help!
