Giriş
From use and abuse, the bottoms of the mouse buttons can wear down and become unable to click the digital buttons inside the mouse.
Neye ihtiyacın var
Flip the mouse over and peel off the stickers on the perimeter of the bottom of the mouse.
Remove the 5 mm round head screw holding the middle piece to the top piece.
The outermost shell will now separate from the middle structure.
Take the plastic buttons (the part that your fingers click) and flip them over.
On the bottom, there should be little plastic towers. Wearing these down can prevent the buttons from clicking properly.
File the bottoms of these towers flat to remove any ridges that prevent proper clicking.
Make sure to file down both towers. In this image, one is left un-filed to show the difference.
This process can also be used for the other buttons on the mouse. Use other guides to disassemble the mouse until the desired button is accessible, and then perform the same filing technique.
Do you realize that the “TTC” click block (whatever it is called) may be faulty, like it is in my mouse. The right one works but the left click does not work and the “towers” on the outermost shell are not worn at all. It is the failure of the “click block” that has “TTC” and “29” on top of it and a tiny white button that makes a clicking sound but does not work. Is there a way to repkace it? Probabaly not, me guess….
20 farklı kişi bu kılavuzu tamamladı.
16 Yorum
Thanks, worked like a charm.
i used a software fix and all my double random clicks has gone , mouserepair.com solved my problem for good.
Youns T -
What if my gaming mouse doesnt have screws??
yep no screws……….so am screwed
Really a great help!
thank you men
Fixed the unclickable button, thanks.. but the wireless mouse stopped working (red diode doesn’t even produce a light).
It stopped all of a sudden (over night, not while I was doing something). It’s not batteries. Can someone help me or it’s dead?
Great guide! useful on my logitech m585 mouse too!
Initially my mouse keeps releasing in the middle of dragging something. After following this guide, it works like brand new!
I accidentally touched the scroller and a silver spring looking thing came out, how do I fix that?
Do you realize that the “TTC” click block (whatever it is called) may be faulty, like it is in my mouse. The right one works but the left click does not work and the “towers” on the outermost shell are not worn at all. It is the failure of the “click block” that has “TTC” and “29” on top of it and a tiny white button that makes a clicking sound but does not work. Is there a way to replace it? Probably not, would be my guess. (Corrected post)
my mouse sucks i peeled off the tape and there is a layer of something blocking the the screw it is a gaming mouse and i got it 2 weeks ago
Nathan Swercewski - Yanıt
My mouse does not have any screws on it what do I do
Blakemoller - Yanıt
Use a spudger
Toon Konings -
