Ana içeriğe geç
Repair Redragon S107 Unresponsive Keys
Neye ihtiyacın var
  1. Repair Redragon S107 Unresponsive Keys, Repair Redragon S107 Unresponsive Keys: adım 1, 1 resimden 1.
    • Unplug the USB cable to prevent issues during the repair.
  2. Repair Redragon S107 Unresponsive Keys: adım 2, 2 resimden 1. Repair Redragon S107 Unresponsive Keys: adım 2, 2 resimden 2.
    • Remove all 13 Phillips screws located on the underside of the keyboard and gently remove the casing.
  3. Repair Redragon S107 Unresponsive Keys: adım 3, 1 resimden 1.
    • Lay the RGB LED panel flat on the desk.
    • Make sure that you do not damage the black wire on the left corner of the keyboard connected to the LED panel.
  4. Repair Redragon S107 Unresponsive Keys: adım 4, 2 resimden 1. Repair Redragon S107 Unresponsive Keys: adım 4, 2 resimden 2.
    • Remove the three screws on the metal bracket located towards the top left on the keyboard.
    • Remove the rubber underneath the metal bar.
  5. Repair Redragon S107 Unresponsive Keys: adım 5, 2 resimden 1. Repair Redragon S107 Unresponsive Keys: adım 5, 2 resimden 2.
    • Use a cotton swab and add isopropyl alcohol to thoroughly clean the green membrane sheet and place the green membrane back onto the key switches.
  6. Repair Redragon S107 Unresponsive Keys: adım 6, 3 resimden 1. Repair Redragon S107 Unresponsive Keys: adım 6, 3 resimden 2. Repair Redragon S107 Unresponsive Keys: adım 6, 3 resimden 3.
    • Use electrical tape to fix each contact strip that connects the green membrane to the motherboard into place.
    • Align the contact strips in place with the black lined traces provided on the motherboard.
  7. Repair Redragon S107 Unresponsive Keys: adım 7, 3 resimden 1. Repair Redragon S107 Unresponsive Keys: adım 7, 3 resimden 2. Repair Redragon S107 Unresponsive Keys: adım 7, 3 resimden 3.
    • Place the rubber and metal bar back into place. Reinstall the three screws tightly as this will ensure no complications with the alignment of contact strips.
  8. Repair Redragon S107 Unresponsive Keys: adım 8, 2 resimden 1. Repair Redragon S107 Unresponsive Keys: adım 8, 2 resimden 2.
    • Place the RGB LED panel back onto the green membrane sheet. Reinstall the casing.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Usman Khan
478 İtibar
2 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 70
Her zaman: 1,122
