Ana içeriğe geç
Giriş
Very often problem with this model. In 60% it can be resolved only with reconnecting the Touchscreen flex / ribbon cable.
If this solution not helped you then you must to change your Touchscreen.
Acer Iconia B1-A71 Touchscreen Replacement
Please SUBSCRIBE to my channel ツ
Parçalar
Hiçbir parça belirtilmedi.
Videoya Genel Bakış
  1. Because I can't switch-off the tablet, I'm using the reset button to do this. Now, remove the back cover. If you have a memory card inside, don't forget to remove it!
    • Because I can't switch-off the tablet, I'm using the reset button to do this.
    • Now, remove the back cover.
    • If you have a memory card inside, don't forget to remove it!
  2. Open the touchscreen flex cable connector and reconnect the cable. . Did you do it successfully?
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
ZFix
178.561 İtibar
315 adet Kılavuz yazıldı
Takım
Master Techs Master Techs üyesi
Community
297 Üyeler
982 adet Kılavuz yazıldı
14 Yorum
Thanks.. it worked for my tab... Great...
pandawa - Yanıt
s'il vous plait vous pouvez m'aider j'ai un problème avec mon Acer B1. problème de démarrage qu'on j'allume il y'a juste Acer qui s'affiche j'ai essayer d'aller en mode recovery (SD IMAGE UPDATE MODE) mais une fois que je clique dessus ça se bloque s'il vous plait besoin de votre aide
omy - Yanıt
If you have a memory card inside, remove it. If you have same problem again, you have a problem with Android OS or a hardware problem.
ZFix -
Great i thought i cannot use my acer anymore, but know its worked thx for the solutions.
Andri Sagita - Yanıt
Thanks for the info. I fixed my tablet before by using the steps. But, I had the same problem again. I tried to fix it again but it's not wrking. So how to fix the problem with Android OS or hardware problem? Cheers.
rinayaya - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 38,676
