Ana içeriğe geç
Repairing Alarm Clock Clock Projector
Neye ihtiyacın var
  1. Repairing Alarm Clock Clock Projector, The issue: adım 1, 1 resimden 1.
    • The Problem: here I should read 12:47
  2. Repairing Alarm Clock Clock Projector: adım 2, 2 resimden 1. Repairing Alarm Clock Clock Projector: adım 2, 2 resimden 2.
    • After removing the 2 screws on the bottom, carefully open the bottom frame, see location of the plastic snaps snaps
  3. Repairing Alarm Clock Clock Projector: adım 3, 3 resimden 1. Repairing Alarm Clock Clock Projector: adım 3, 3 resimden 2. Repairing Alarm Clock Clock Projector: adım 3, 3 resimden 3.
    • Removes the back panel, taking care of the other plastic snaps
    • The projector and its optics is shown in the blue square
  4. Repairing Alarm Clock Clock Projector, The optics: adım 4, 3 resimden 1. Repairing Alarm Clock Clock Projector, The optics: adım 4, 3 resimden 2. Repairing Alarm Clock Clock Projector, The optics: adım 4, 3 resimden 3.
    • cables are tied together with a simple ribbon, in general the inner construction seems very cheap
    • The Projector is made of three parts:
    • A red LED
    • The display with its controller
    • the lens with focus mechanics
    • All parts are kept by tiny screws that you have to remove
    • Take extra caution when handling the display, the flat cable is very weak and can be damaged by improper handling
  5. Repairing Alarm Clock Clock Projector: adım 5, 3 resimden 1. Repairing Alarm Clock Clock Projector: adım 5, 3 resimden 2. Repairing Alarm Clock Clock Projector: adım 5, 3 resimden 3.
    • Carefully remove display from its supporting frame
    • The issue should be ralated to flat cable connecting display to controller
  6. Repairing Alarm Clock Clock Projector: adım 6, 3 resimden 1. Repairing Alarm Clock Clock Projector: adım 6, 3 resimden 2. Repairing Alarm Clock Clock Projector: adım 6, 3 resimden 3.
    • Verify that moving the flat the display returns to work
    • put a stiffner on controller side and close to the display
    • if everything is working, reassemble the clock by doing the steps in reverse order
  7. Repairing Alarm Clock Clock Projector: adım 7, 1 resimden 1.
    • Problem solved.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Andrea Gangemi
172 İtibar
1 Kılavuz yazıldı
6Kılavuz Yorumları
The clock projection displays only partial numbers.one number is missing. The face on the clock displays perfect. It's just The projection on the wall that's missing a digit
eacoch - Yanıt Paylaş
my Peakeep clock keeps the correct time but you can't see the time clearly. It's as if the light is turned off.
serena williams - Yanıt Paylaş
Thank you for this post! It was the exact starting point to fix my projection clock which was looking dull and had lost a few segments. While the addition of supporting tape helped for a short period, doing it again in conjunction with Step 6 of the following link (http://www.instructables.com/id/How-to-r...) - Applying heat - to the ribbon contact points was the ticket that restored my projection clock functionality.
Adam - Yanıt Paylaş
Hi Adam, glad to helped you
Andrea Gangemi - Paylaş
The display on my clock is missing parts of a number but project correct time , help ?
mandzb87 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 38
Son 30 gün: 131
Her zaman: 14,851
