Ana içeriğe geç
Repairing Apple 30-pin to USB Cable Connector
Neye ihtiyacın var
  1. Repairing Apple 30-pin to USB Cable Connector, Make a connector opener: adım 1, 1 resimden 1.
    • Take a pin with a plastic head. Place the tip over a flat, heavy duty surface (such as a cold chisel blade) and tap with a hammer to flatten. This should only take 5 to 10 taps. Make sure the blade is flat and the edge is smooth.
    FixBot'a Sor
    Yorum Ekle
  2. Repairing Apple 30-pin to USB Cable Connector, Construction of 30-pin connector: adım 2, 2 resimden 1. Repairing Apple 30-pin to USB Cable Connector, Construction of 30-pin connector: adım 2, 2 resimden 2.
    • The 30-pin connector comprises of 3 parts: 1) the plastic outer shell, 2) the mid plastic sleeve, 3) the inner metal connector.
    • The middle sleeve has a lip on both rounded ends.
    • The outer connector has a corresponding plastic bump that snaps under the sleeve lip to hold them together.
    FixBot'a Sor
    Yorum Ekle
  3. Repairing Apple 30-pin to USB Cable Connector: adım 3, 1 resimden 1.
    • Make a depth guide mark on the tool made in step 1.
    • The mark should start 3 mm from the tip of the tool.
    FixBot'a Sor
    Yorum Ekle
  4. Repairing Apple 30-pin to USB Cable Connector, Inserting the tool: adım 4, 1 resimden 1.
    • Work the tool between the outer shell and middle sleeve at one end of the connector until the depth mark is reached.
    • You may need to work slightly from the side if going directly in is too difficult.
    • The plastic head on the tool will be very helpful to allow enough pressure to be exerted.
    FixBot'a Sor
    Yorum Ekle
  5. Repairing Apple 30-pin to USB Cable Connector, Separating the outer shell: adım 5, 1 resimden 1.
    • Once the tool is at the required depth and location that side of the sleeve and connector can be released.
    • Remove the tool and repeat on the other side of the shell. Be careful not to push the first side back in to the shell in the process.
    • Once both sides are released slide the outer shell down the cable.
    • Wrap the frayed cable with a little tape if it is difficult to get through the hole in the shell.
    FixBot'a Sor
    Yorum Ekle
  6. Repairing Apple 30-pin to USB Cable Connector, The parts of an Apple cable: adım 6, 2 resimden 1. Repairing Apple 30-pin to USB Cable Connector, The parts of an Apple cable: adım 6, 2 resimden 2.
    • An Apple cable has a much more robust 30-pin connector than cheaper non-Apple cables. The Apple connector has 2 plates soldered to the back of it - one on the top and another on the bottom. Cheaper connectors do not have these shielding plates.
    • An Apple cable comprises of: 1) 4 wires, 2) a strain relieving thread, 3) shielding mesh around the wires and strain relieving thread, 4) outer cover.
    FixBot'a Sor
    Yorum Ekle
  7. Repairing Apple 30-pin to USB Cable Connector, Removing the shielding plate: adım 7, 2 resimden 1. Repairing Apple 30-pin to USB Cable Connector, Removing the shielding plate: adım 7, 2 resimden 2.
    • Access to the circuit board with the wire terminals is by removing the plate with 2 smaller solder points almost at the corners of the shielding plate.
    • Keeping the 2 solder points hot, work a flat bladed knife carefully between the shielding plate and connector so as to not cut the wires underneath until the plate releases.
    FixBot'a Sor
    Yorum Ekle
  8. Repairing Apple 30-pin to USB Cable Connector, Accessing the wire terminations.: adım 8, 1 resimden 1.
    • It may be necessary to remove some of the plastic filling to access the wire terminals.
    • Here, only the shielding needs repair.
    • Carefully slit the external strain releaser.
    • Prise up the internal strain releaser.
    • Insert a piece of cable such as a strand of Category 5 cabling.
    FixBot'a Sor
    Yorum Ekle
  9. Repairing Apple 30-pin to USB Cable Connector, Attach wire to terminal: adım 9, 1 resimden 1.
    • Solder the wire to the correct terminal.
    • Solder the other end to the frayed shielding.
    FixBot'a Sor
    Yorum Ekle
  10. Repairing Apple 30-pin to USB Cable Connector, Test for short circuits: adım 10, 1 resimden 1.
    • Test for continuity of shielding between 30-pin connector and USB connector. The resistance should be much less than 1 Ohm.
    • Test for short circuits between the 4 pins on the USB connector. There should be none.
    FixBot'a Sor
    Yorum Ekle
  11. Repairing Apple 30-pin to USB Cable Connector, Reassemble: adım 11, 1 resimden 1.
    • Lightly wrap the wires with electrical tape.
    • Reinstall the cover plate.
    • Install the middle sleeve.
    • Slide the outer shell over the connector.
    • It may be necessary to enlarge the hole at the back of the outer shell to allow it to fit over the taped wires.
    • Wrap electrical tape from the back of the shell down the wires until it extends about 5 cm, reducing the overlap as you go. This will act as a poor man's external strain reliever.
    FixBot'a Sor
    Yorum Ekle
Sonuç
18 farklı kişi bu kılavuzu tamamladı.
tim
688 İtibar
1 Kılavuz yazıldı
5Kılavuz Yorumları
This is a great guide. I figured out for myself, how to open iPod connector, but I could have saved some struggle if I had followed this guide.
unsubstantiated - Yanıt Paylaş
What poop. They don't show the connections to solder to.
Untrepid One - Yanıt Paylaş
Tengo 3 cables desconectados sólo el verde soldado en un pin de un extremo rojo, blanco y negro dónde van?
Quiero volver a cargar la batería.
carlos dante Guziuk - Yanıt Paylaş
Carlos,
I did a search for ‘apple 30pin connector pinout’ and found this. I hope it helps.
http://mobilescomplaint.blogspot.com/201...
Tim
tim - Yanıt Paylaş
donde van conectados los cables del USB a cada pin del socket de 30 pines
Vladimir Velázquez - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 63
Son 30 gün: 255
Her zaman: 57,730
