Ana içeriğe geç
Repairing Billion Router BiPAC 7404VNPX VOIP
  1. Repairing Billion Router BiPAC 7404VNPX VOIP, Repairing Billion Router BiPAC 7404VNPX VOIP: adım 1, 1 resimden 1.
    • Turning the Router over you find 4 rubber feet hiding 4 Philips head screws.
    • Remove the screws and turn the router back upright.
    • The top of the case should now lift off.
  2. Repairing Billion Router BiPAC 7404VNPX VOIP: adım 2, 2 resimden 1. Repairing Billion Router BiPAC 7404VNPX VOIP: adım 2, 2 resimden 2.
    • The C928 Capacitor 100uF 25v is the one talked about in the forum mentioned in the intro.
    • While I was checking the solder side of the board I noticed there was a bad solder joint on this cap. You cant see it at this resolution though.
    • While checking the state of the other caps on the board I noticed that this one 1000uF 10v was also showing signs of heat stress.
    • Both capacitors were replaced.
    • You can see the new caps in position on the right.
    • For the princely sum AU $1.20 in parts, 20 mins setting up, 5 mins to fix, 5 mins to put it all away I have saved myself aprox $200 for a new VOIP router :)
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
mikejgrantham
146 İtibar
1 Kılavuz yazıldı
2 Yorum
Champion!
Thanks for this.
$1.30 in parts saved me going out buying a new VOIP adapter.
Nick Gustafsson - Yanıt
No worries, Glad it helped :)
mikejgrantham - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 1,528
