Giriş
Here I am rebuilding, actually more building, a battery of the electric screw driver. The original battery is no longer available so I decided to build my own i order to continue to use the screwdriver. The battery cell I am using are 4/5 SC (sub C) size. Meaning they are 4/5 the size of a C-Cell. They are 23 x 34 mm in size with a capacity of 2000mAh and 1.2 Volts.
Neye ihtiyacın var
Here is the original battery. Three cells surrounded by a soft plastic sheathing
Cut the plastic (I used a utility knife) away.
Now the three cells are clearly visible and the way they are connected in series. Meaning positive from one cell to negative on the next cell. Each cell separated by a rubber insulator
Top to bottom on this image shows the insulator that is on the top portion of the cells. Next are the old three cells and bottom the new cells.
The contacts on the old cells appear to be spot welded to make the connection.
Separate the connections with either a pair of side cutters or a pair of scissor. This will allow you to remove the insulators.
All three cells soldered together, positive to negative end, creating a series connection.
The original battery was wrapped in some soft plastic. I decided to use 1 1/4 inch heat shrink tubing. Black electric tape might work just as well, but I used what I had on hand.
Heatshrink tubing placed over the cells
I placed a clamp from end to end. This will prevent any exposure to hot parts, will allow movement of the battery and still maintain alignment.
Here is the two speed heatgun I use for my projects.
Simply apply constant heat to the tubing by moving the heatgun along the heatshrink tubing.
Here is the battery with the heatshrink tubing attached.
Obviously the contacts are being than the connector. (The corrosion visible on the connector was cleaned of during the installation)
Trim the contacts with either a pair of sidecutters, or like in my case, use a pair of scissors.
Once the contacts are trimmed to size, the battery is ready for installation into the screwdriver. There is a separate guide for that. Total cost for this was around $9.00 for the cells.
Excellent guide. Very useful for guys who try to maintain old stuff.Simple step by step description and picturisation. Hats off to you for the painstaking work.
7 farklı kişi bu kılavuzu tamamladı.
3 Yorum
What are the specs on the batteries, and where did you get them? I don’t see any on mine. Thanks!
eBay has the exact set the 4/5 sc sub c are the shorter ones easy to find with connecters already on each end of battery I'm rebuilding mine soon as they come in I'll post results
