1. Before disassembling the blender base, make sure the blender disconnected from any power outlet. Lift the jar straight up from the base without tilting the jar.
    • Before disassembling the blender base, make sure the blender disconnected from any power outlet.
    • Lift the jar straight up from the base without tilting the jar.
  2. Remove the top three 1/4 inch base screws using a Philip's head screwdriver.
    • Remove the top three 1/4 inch base screws using a Philip's head screwdriver.
  3. Remove the two base leg covers next to the power cord using pliers or a flat-head screwdriver. This provides access to the base screws beneath.
    • Remove the two base leg covers next to the power cord using pliers or a flat-head screwdriver.
    • This provides access to the base screws beneath.
  4. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
    Ever fixed something? That’s Genius.
    Share your story with #ImAGenius for a chance to win $100!
    We Are All Geniuses
    Share your repair story with #ImAGenius
  5. Remove the following screws that secure the top and  bottom halves of the base.
    • Remove the following screws that secure the top and bottom halves of the base.
      • One 1/4 Phillips screw
      • One TA-20 screw
    • Both screwdrivers must have a minimum of a three inch shank (length).
    • Screwdrivers with extenders will not fit down the access holes.
  6. Lift the top half of the base from the bottom half of the base to reveal the internal mechanism.
    • Lift the top half of the base from the bottom half of the base to reveal the internal mechanism.
  7. Tug on wires in the marked locations to make sure they are secure.
    • Tug on wires in the marked locations to make sure they are secure.
    • If the wire stays still, the connection is secure.
      • If you still have problems with the blender, it is probably a problem with the motor. Since the motor is irreplaceable, you will have to order a new blender.
  8. If the wire comes off, the connection is insecure. You will need to solder the connection to make it solid again.
    • If the wire comes off, the connection is insecure. You will need to solder the connection to make it solid again.
    • If you don't know how to solder, here is a link to show you how. http://www.aaroncake.net/electronics/sol...
Sonuç
4 başka kişi bu kılavuzu tamamladı.
Elmer Pres Urbano
142 İtibar
1 Kılavuz yazıldı
Takım
Cal Poly, Team 6-34, Regan Fall 2012 Cal Poly, Team 6-34, Regan Fall 2012 üyesi
CPSU-REGAN-F12S6G34
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 6
Son 30 Gün: 24
Her zaman: 2,463
