Ana içeriğe geç
Repairing Bose On-Ear headphones Shorted Right earphone
Neye ihtiyacın var
  1. Repairing Bose On-Ear headphones Shorted Right earphone, Repairing Bose On-Ear headphones Shorted Right earphone: adım 1, 2 resimden 1. Repairing Bose On-Ear headphones Shorted Right earphone, Repairing Bose On-Ear headphones Shorted Right earphone: adım 1, 2 resimden 2.
    • To repair a short in the wires, the head band has two screws, just above the headphones cups.
  2. Repairing Bose On-Ear headphones Shorted Right earphone: adım 2, 2 resimden 1. Repairing Bose On-Ear headphones Shorted Right earphone: adım 2, 2 resimden 2.
    • After removing the two small screws, try closing the headband to it's shortest position. The outer panel will pop out toward the bottom edge.
    • You can then slide the panel out from under the collar. The collar may slide out of place while working, but can easily be slid back during re-assembly.
  3. Repairing Bose On-Ear headphones Shorted Right earphone: adım 3, 2 resimden 1. Repairing Bose On-Ear headphones Shorted Right earphone: adım 3, 2 resimden 2.
    • After inspecting the wire inside, you may notice cracks in the corners were the wires bend when the headphones are folded. I cut a thin strip of electrical tape to use as reinforcement.
    • After sliding the collar up, you can extend the wire, giving you better access for wrapping or replacing.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Designer Dan
274 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 5,185
