Ana içeriğe geç
Repairing Canon PowerShot Lens Error E-18
Neye ihtiyacın var
    1. Repairing Canon PowerShot Lens Error E-18, Repairing Canon PowerShot Lens Error E-18: adım 1, 1 resimden 1.
      • Place camera lens facing upwards on the table.
      • Press and hold down the power button.
      • Simultaneously press down the shutter button.
      FixBot'a Sor
      Yorum Ekle
    2. Repairing Canon PowerShot Lens Error E-18: adım 2, 1 resimden 1.
      • Replace the batteries in the camera.
      • To open the battery cover slide the black lever on the underside of the camera and pull the cover toward the front.
      • Remove the old batteries from the camera and wait a few moments.
      • Put in a fresh set of batteries.
      • Close battery slide and power camera back on.
      FixBot'a Sor
      Yorum Ekle
    3. Repairing Canon PowerShot Lens Error E-18: adım 3, 1 resimden 1.
      • Put blow dryer in the "no heat" setting prior to plugging it in.
      • Plug in and turn the blow dryer on.
      • Blow air in the gaps between the lens.
      FixBot'a Sor
      Yorum Ekle
Sonuç
In conclusion, using this guide to fix the E-18 on the lens of the Canon PowerShot A80,will allow the camera to capture photos once again. To reassemble your device, follow these instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
Tim
172 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 7-31, Regan Winter 2011 Cal Poly, Team 7-31, Regan Winter 2011 üyesi
CPSU-REGAN-W11S7G31
6 Üyeler
12 adet Kılavuz yazıldı
1Rehber Yorum
merci! mon appareil fonctionne à nouveau
nadia.labadi - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 29
Son 30 gün: 122
Her zaman: 8,799
