Ana içeriğe geç
Repairing Cup Holder for 2008 328i BMW
Neye ihtiyacın var
  1. Repairing Cup Holder for 2008 328i BMW, Repairing Cup Holder for 2008 328i BMW: adım 1, 3 resimden 1. Repairing Cup Holder for 2008 328i BMW, Repairing Cup Holder for 2008 328i BMW: adım 1, 3 resimden 2. Repairing Cup Holder for 2008 328i BMW, Repairing Cup Holder for 2008 328i BMW: adım 1, 3 resimden 3.
    • Apply putty knife to edge of cover until it pops open
    • Remove screws off of broken cup holder
    • Take cup holder out
  2. Repairing Cup Holder for 2008 328i BMW: adım 2, 3 resimden 1. Repairing Cup Holder for 2008 328i BMW: adım 2, 3 resimden 2. Repairing Cup Holder for 2008 328i BMW: adım 2, 3 resimden 3.
    • Remove plastic cover on cup holder by pulling apart where the lips meet
    • Locate spring in device
  3. Repairing Cup Holder for 2008 328i BMW: adım 3, 2 resimden 1. Repairing Cup Holder for 2008 328i BMW: adım 3, 2 resimden 2.
    • Fully take apart the cup holder to get to the inside of the cup holder
    • Locate where spring is placed
  4. Repairing Cup Holder for 2008 328i BMW: adım 4, 3 resimden 1. Repairing Cup Holder for 2008 328i BMW: adım 4, 3 resimden 2. Repairing Cup Holder for 2008 328i BMW: adım 4, 3 resimden 3.
    • Locate where the spring connects
    • If hole is not broken then just apply spring into hole
    • If the hole broke, like in this case here, then drill a hole the size of the spring around the same spot of the other hole
    • Caution: Be careful drilling the hole, the plastic is slippery when in contact with drill bit
  5. Repairing Cup Holder for 2008 328i BMW: adım 5, 3 resimden 1. Repairing Cup Holder for 2008 328i BMW: adım 5, 3 resimden 2. Repairing Cup Holder for 2008 328i BMW: adım 5, 3 resimden 3.
    • Test to make sure spring is properly working
    • Reassemble the cup holder
  6. Repairing Cup Holder for 2008 328i BMW: adım 6, 3 resimden 1. Repairing Cup Holder for 2008 328i BMW: adım 6, 3 resimden 2. Repairing Cup Holder for 2008 328i BMW: adım 6, 3 resimden 3.
    • Put cup holder back in place
    • Screw in screws
  7. Repairing Cup Holder for 2008 328i BMW: adım 7, 1 resimden 1.
    • Check to make sure cup holder works
    • Start to put on cover by lining up holes
  8. Repairing Cup Holder for 2008 328i BMW: adım 8, 3 resimden 1. Repairing Cup Holder for 2008 328i BMW: adım 8, 3 resimden 2. Repairing Cup Holder for 2008 328i BMW: adım 8, 3 resimden 3.
    • Press firmly on cover all around until it is fully on
  9. Repairing Cup Holder for 2008 328i BMW: adım 9, 2 resimden 1. Repairing Cup Holder for 2008 328i BMW: adım 9, 2 resimden 2.
    • Enjoy your fixed cup holder!
Sonuç
Follow these steps step by step to get your broken cup holder fixed.
18 farklı kişi bu kılavuzu tamamladı.
Michael Tapia
499 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 15-5, Green Fall 2015 Cal Poly, Team 15-5, Green Fall 2015 üyesi
CPSU-GREEN-F15S15G5
4 Üyeler
14 adet Kılavuz yazıldı
6 Yorum
Easy fix that saved over $60 if I had to purchase a new part and much much more if the the dealer were to have fixed this. Thank you
Keith La Plain - Yanıt
clever idea when plastic holding the spring hook is broken. nice hack of a fix.
Nicholas McKoy - Yanıt
Is there any way to purchase just the spring? In my case the plastic is fine, it’s the shaped metal tip of the spring that sheared off somehow!? I also need the tentioner.
Ryan Cornell - Yanıt
This happened to me as well. I broke off the end of the coil/spring while bending to make a “hook” shape.
I looked for purchasing just the spring, but could not find it. Next up was the entire cupholder apparatus, either used ($~26), URO ($~39), or OEM/genuine BMW ($60-75+). This isn’t cheap and is not actually necessary to buy anything ,though.
Much easier is what I did instead, which was taking advantage of the coil material’s rigid/”easily-snap-off-able” property to make a new (wider) hook. I pulled the snapped end of the coil out a little, then put in a thin screwdriver to kind of hold the coil out extended. Next I used flat nose pliers to hold the end flat, while using long nose pliers to break off a new gap on both sides, effectively making a new “t” end. Then of course I VERY GENTLY bent it around to make a “hook”. I gently clipped the new spring hook into the preexisting plastic hole. It works for new after reinstalling. We’ll see how it holds up!
Benjamin Castellon -
Dealer wanted $180. Flat spring has T on end and locks into corresponding T in plastic. My plastic was broken out on one side. I merely took a bit in my dremel, and made the old T deeper in order to catch the metal end.
Larry Pockras - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 88
Her zaman: 26,911
