Ana içeriğe geç
Repairing EPSON B-510DN Error 0xF2 or 0xF3
Neye ihtiyacın var
  1. Repairing EPSON B-510DN Error 0xF2 or 0xF3, Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 1, 3 resimden 1. Repairing EPSON B-510DN Error 0xF2 or 0xF3, Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 1, 3 resimden 2. Repairing EPSON B-510DN Error 0xF2 or 0xF3, Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 1, 3 resimden 3.
    • Remove the paper tray
    • Remove the paper cassette
    • Remove the ink tanks.
  2. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 2, 2 resimden 1. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 2, 2 resimden 2.
    • Remove the opening covers.
  3. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 3, 1 resimden 1.
    • Remove the rear component
  4. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 4, 1 resimden 1.
    • Dismount the Ink lever
  5. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 5, 2 resimden 1. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 5, 2 resimden 2.
    • Remove the front panel screws
  6. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 6, 2 resimden 1. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 6, 2 resimden 2.
    • Dismount LCD Panel
  7. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 7, 3 resimden 1. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 7, 3 resimden 2. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 7, 3 resimden 3.
  8. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 8, 3 resimden 1. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 8, 3 resimden 2. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 8, 3 resimden 3.
    • Remove the back panel screws
  9. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 9, 2 resimden 1. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 9, 2 resimden 2.
    • Remove the last back panel screw (hidden behind the LCD display)
  10. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 10, 1 resimden 1.
    • Remove the back ethernet panel
  11. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 11, 3 resimden 1. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 11, 3 resimden 2. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 11, 3 resimden 3.
    • Remove the main back panel, being careful not to damage the LCD display
  12. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 12, 2 resimden 1. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 12, 2 resimden 2.
    • Clean the left roller very gently with a dry tissue or a soft brush
  13. Repairing EPSON B-510DN Error 0xF2 or 0xF3, Clean the right encoder: adım 13, 3 resimden 1. Repairing EPSON B-510DN Error 0xF2 or 0xF3, Clean the right encoder: adım 13, 3 resimden 2. Repairing EPSON B-510DN Error 0xF2 or 0xF3, Clean the right encoder: adım 13, 3 resimden 3.
    • Clean the right encoder very gently with a dry tissue or a soft brush.
  14. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 14, 2 resimden 1. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 14, 2 resimden 2.
    • If you want to test the printer you need to insert paper, and cover 2 switches with tape.
  15. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 15, 1 resimden 1.
    • Reassemble the printer (remove the tape first if you have used it) following these instructions in reverse.
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
delete
541 İtibar
1 Kılavuz yazıldı
14 Yorum
It's works, thanks
Thom - Yanıt
Perfect. I used this guide to disassemble my printer.
I had 0xF1 and/or 0xF4. The reason was some paper stuck between the gears of the paper feed (in this guide step 12).
I hope this hint will help others. I didn't find any info about these error code online.
DumahBrazorf - Yanıt
Error descriptions I found here - http://www.fatalerrors.info/
John Smith -
Thank you very much ! This is a very useful and beautifully documented guide. Best wishes and greetings to the kind author of this guide from Bratislava, Slovakia.
George Pekarovic
George - Yanıt
muito obrigado pela ajuda
Filipe Rocha - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 32
Son 30 gün: 127
Her zaman: 59,269
