Ana içeriğe geç
Repairing EPSON B-510DN Error 0xF2 or 0xF3
Neye ihtiyacın var
  1. Repairing EPSON B-510DN Error 0xF2 or 0xF3, Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 1, 3 resimden 1. Repairing EPSON B-510DN Error 0xF2 or 0xF3, Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 1, 3 resimden 2. Repairing EPSON B-510DN Error 0xF2 or 0xF3, Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 1, 3 resimden 3.
    • Remove the paper tray
    • Remove the paper cassette
    • Remove the ink tanks.
  2. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 2, 2 resimden 1. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 2, 2 resimden 2.
    • Remove the opening covers.
  3. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 3, 1 resimden 1.
    • Remove the rear component
  4. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 4, 1 resimden 1.
    • Dismount the Ink lever
  5. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 5, 2 resimden 1. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 5, 2 resimden 2.
    • Remove the front panel screws
  6. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 6, 2 resimden 1. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 6, 2 resimden 2.
    • Dismount LCD Panel
  7. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 7, 3 resimden 1. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 7, 3 resimden 2. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 7, 3 resimden 3.
  8. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 8, 3 resimden 1. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 8, 3 resimden 2. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 8, 3 resimden 3.
    • Remove the back panel screws
  9. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 9, 2 resimden 1. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 9, 2 resimden 2.
    • Remove the last back panel screw (hidden behind the LCD display)
  10. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 10, 1 resimden 1.
    • Remove the back ethernet panel
  11. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 11, 3 resimden 1. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 11, 3 resimden 2. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 11, 3 resimden 3.
    • Remove the main back panel, being careful not to damage the LCD display
  12. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 12, 2 resimden 1. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 12, 2 resimden 2.
    • Clean the left roller very gently with a dry tissue or a soft brush
  13. Repairing EPSON B-510DN Error 0xF2 or 0xF3, Clean the right encoder: adım 13, 3 resimden 1. Repairing EPSON B-510DN Error 0xF2 or 0xF3, Clean the right encoder: adım 13, 3 resimden 2. Repairing EPSON B-510DN Error 0xF2 or 0xF3, Clean the right encoder: adım 13, 3 resimden 3.
    • Clean the right encoder very gently with a dry tissue or a soft brush.
  14. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 14, 2 resimden 1. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 14, 2 resimden 2.
    • If you want to test the printer you need to insert paper, and cover 2 switches with tape.
  15. Repairing EPSON B-510DN Error 0xF2 or 0xF3: adım 15, 1 resimden 1.
    • Reassemble the printer (remove the tape first if you have used it) following these instructions in reverse.
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
delete
541 İtibar
1 Kılavuz yazıldı
14 Yorum
It's works, thanks
Thom - Yanıt
Perfect. I used this guide to disassemble my printer.
I had 0xF1 and/or 0xF4. The reason was some paper stuck between the gears of the paper feed (in this guide step 12).
I hope this hint will help others. I didn't find any info about these error code online.
DumahBrazorf - Yanıt
Error descriptions I found here - http://www.fatalerrors.info/
John Smith -
Thank you very much ! This is a very useful and beautifully documented guide. Best wishes and greetings to the kind author of this guide from Bratislava, Slovakia.
George Pekarovic
George - Yanıt
muito obrigado pela ajuda
Filipe Rocha - Yanıt
You are awesome! It helped me! Thanks very much!
martinjurtik - Yanıt
Hi
I keep getting on an Epson B-500DN printer error restart printer with the paper and ink led blinking orange.
Disassemble the printer made a full cleaning (all encoding wheels too) and keep getting this error, the printer goes until ready, then as soon as it says printing it shows the error.
anyone ???
invitro59 - Yanıt
OMG.
I had error oxF3.
I was set to bin this ace printer, I just googled the error code and bam this guide came up. This was awesome, I only found a little dirt on the step 12 clear plastic disc, nothing visible on step 13. Put the cartridges back in, maintenance tank paper tray and hooked up the power and network cable, and covered the 2 switches with tape. then OMG it worked. Now need to work out which screw goes where and reassemble.
Malcolm Taylor - Yanıt
OK. Seguito con semplicità e Risolto il Problema. Adesso funziona. OK Thank you
Foto Diego - Yanıt
What about Erro code 0xF3 in Epson WF7610
ABEL MLIGA - Yanıt
Yes what about the WF7610 error code 0xF3?!
David Imondi - Yanıt
I have Epson XP 710 which shows an error code 0×4f what can i do for it. When i turned it on it's starts well with Epson logo but there's a sound of running the gears in fast speed for a few seconds after this it's showing the error just after pooping up the menu screen no head movement. Kindly forward me with possible assistance
abab6330 - Yanıt
Constantly gives 0xF4. If you move the head to the center, when it is turned on, it goes to the left, then goes to its place and when Parking the engine PF PID (left) twitches a little, and the scoreboard error 0xF4. In printer all cleaned up, blew. Cartridges took out, got a diaper. Before that, it was so that it prints, then outputs 0xF4 and sometimes 0xF1. What to do?
561054 - Yanıt
Works very good. The photos for the right sight could be better, but when you know how it looks on the left its possible to find.
Ralf Sagorny
Ralf Sagorny - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 26
Son 30 gün: 86
Her zaman: 59,753
