Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the paper tray
Remove the paper cassette
Remove the ink tanks.
Remove the last back panel screw (hidden behind the LCD display)
Remove the main back panel, being careful not to damage the LCD display
Clean the left roller very gently with a dry tissue or a soft brush
Clean the right encoder very gently with a dry tissue or a soft brush.
If you want to test the printer you need to insert paper, and cover 2 switches with tape.
Reassemble the printer (remove the tape first if you have used it) following these instructions in reverse.
16 farklı kişi bu kılavuzu tamamladı.
14 Yorum
Perfect. I used this guide to disassemble my printer.
I had 0xF1 and/or 0xF4. The reason was some paper stuck between the gears of the paper feed (in this guide step 12).
I hope this hint will help others. I didn't find any info about these error code online.
Error descriptions I found here - http://www.fatalerrors.info/
muito obrigado pela ajuda
